magnum vs LA questions
#84782
07/06/08 12:09 PM
07/06/08 12:09 PM
Posts: 5,037 hi
sharpie
Moparts Linguist
Moparts Linguist
hi
I have a 98 Magnum 5.9, and I know whether the larger componants (heads, pistons, front cover, gaskets) can be swapped, but I am unsure on the smaller parts. Specifically:
1. bearings (main, rod, and cam)?
2. timing gears and chain?
3. distributor shaft?
4. freeze plugs?
5. pushrods (the length)?
6. lifters (I am going to use hydraulic, but can I use LA hydraulic lifters or should I use Magnum haydraulic lifters)?
Re: magnum vs LA questions
[Re: sharpie]
#84783
07/06/08 12:34 PM
07/06/08 12:34 PM
Posts: 2,344 Cincinnati, OH
6T6Cuda
Cincinnati, OH
4. freeze plugs?
1. I am almost sure the bearings are all the same (the magnum may use some low resistance one (I know the rings are a lighter & I think the piston is lighter then an LA - thus they need a different ballance).
2. Not sure about the timing gears/chain, but all stock magnums were fuel injected so the have a different timing chain cover w/o a place to mount a fuel pump
3. Not sure what you are asking, stock magnums have a non-adjustable dist (they have a small slot that locks it in place). Magnums use a different cap
4. I would think the freeze plugs would mostly be the same.
5. Push rods - not sure about the length, but I know they are hollow (for pushrod oiling - LA used rocker shaft oiling) I would assume the length is different. If you want to use the magnum roller setup you need to get a magnum block with the holddown for the lifters.
6. You can put LA lifters in a magnum, but not the other way around, I would go with the magnum roller setup if you can with todays oils
[Re: 6T6Cuda]
#84784
07/06/08 01:20 PM
07/06/08 01:20 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Rod and main bearings are all the same. You can use LA cam bearings in a magnum but not the other way, some don't have the holes to oil the rocker shaft. If you are putting magnum heads on an LA then you can use the magnum cam bearings also.
Timing gears and chains are completly interchangeable, even the poly 318. When I put a timing chain in either one I always tell the parts guys I am building a 340 and they give me a double roller chain for pretty cheap.
On the distributer shaft if you are talking about the intermediate shaft between the cam and oil pump, they are all the same, even the old poly 318.
Freeze plugs are all the same size in the block. Some locations are in slightly different places but the sizes are all the same. I think the heads use slightly different size plugs.
Pushrods are 3 different lengths. LAs used one length for flat tappet cams, another for the later 80s roller motors and the magnums used a 3rd length that was also hollow. If you want to put magnum heads on an LA block with a factory roller cam set up, just use the magnum PRs. If you want to put the magnum heads on a motor with flat tappet cam you need to put custom PRs 7.625 inches in it, mopar performance sells some specifically for this. In either case, roller or flat tappet you need to make sure the lifters have a hole in the center of the cup to oil the rockers through the pushrods and the pushrods need to be hollow also.
[Re: sharpie]
#84786
07/06/08 04:29 PM
07/06/08 04:29 PM
HotRodDave
Kalispell Mt.
Cam bearings do not come with a cam. You have to get them seperate or get a overhaul kit that comes with them.
As for the XE268H it is a very good cam but it is a flat tappet cam and will need the mopar conversion 7.625 pushrods and not the stock magnum ones. Mancini is the cheapest place to get them that I have found.
[Re: HotRodDave]
#84787
07/06/08 09:56 PM
07/06/08 09:56 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
or return the comp XE268 and buy a comp XR265HR roller cam for the magnum, and reuse the stock magnum lifters.
[Re: HotRodDave]
#84789
07/07/08 01:02 PM
07/07/08 01:02 PM
Posts: 1,396 Mass
dgc333
Mass
The base circle on the XE268H cam is small enough that the conversion push rods are on the edge of being to short. I would measure the preload on the lifter and select a push rod of the length needed. I wound up using a pushrod that is 7.650" long. I had orignally built the engine with the conversion pushrods and always had a lot of valve clatter when cold.
[Re: dgc333]
#84790
07/07/08 05:18 PM
07/07/08 05:18 PM
HotRodDave
Kalispell Mt.
I had a set of the conversion pushrods on a crane 284 cam and with just a square decking of the block they were almost botteming out all the lifters, it actually ran fine but the plungers were pretty far down.
[Re: HotRodDave]
#84792
07/08/08 05:00 PM
07/08/08 05:00 PM
Posts: 1,396 Mass
dgc333
Mass
All the more reason to check before throughin it together. I had my block zero decked. They took aapprox. 0.020" off each side and the conversion push rods barely preloaded the lifter 0.020.
Don't know where the variation engine to engine comes from maybe the bosses on the head the pedastels mount to or the pedastels them selves.
[Re: dgc333]
#84793
07/08/08 08:22 PM
07/08/08 08:22 PM
HotRodDave
Kalispell Mt.
A million different places tolerances can stack up to one extreme or the other, deck height, rocker pad height, gasket thickness, base circle of the cam, height of the lifters from face to cup, exact cam location... all kinds of things so yeah you need to measure it.
