440 Carter AVS carbs? #847773
11/07/10 01:19 AM
11/07/10 01:19 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Many of the early 70's 440 engines used a single Carter AVS 4966S carb. Can anyone tell me the size of this carb? Thanks!
Re: 440 Carter AVS carbs? [Re: polkat] #847774
11/07/10 01:23 AM
11/07/10 01:23 AM
Cab_Burge Online work
Cab_Burge  Online Work
Supposedly 750 CFM according to Carter and Mopar and my shaky memeory
Re: 440 Carter AVS carbs? [Re: polkat] #847775
11/07/10 06:47 AM
11/07/10 06:47 AM
New York
polyspheric Offline
polyspheric  Offline
New York
580
Boffin Emeritus
Re: 440 Carter AVS carbs? [Re: polyspheric] #847776
11/07/10 11:28 AM
11/07/10 11:28 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
The 4966 is 625 CFM. It does not have the bigger primaries like the 440 HP cars had in the late 60s. It is that same size as the 383 and 340 cars used.
Re: 440 Carter AVS carbs? [Re: polkat] #847777
11/07/10 12:49 PM
11/07/10 12:49 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
is this a race question ?
Re: 440 Carter AVS carbs? [Re: JohnRR] #847778
11/07/10 02:42 PM
11/07/10 02:42 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
4966 is from a 71 lo po 440. It isn't a 750 like others have already said.
Re: 440 Carter AVS carbs? [Re: JohnRR] #847779
11/07/10 02:53 PM
11/07/10 02:53 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
It could be, depends on where he is putting that carter and possibly how many he is using. Two on a Max Wedge cross ram could be a racing application.
Getting old just means you were smarter than some and luckier than others.
