W.A.R.P performance Tube Front end Anyone have one? #847127
11/06/10 11:33 AM
11/06/10 11:33 AM
Iowa
9
9second_bottle Offline OP
Iowa
I found this front end on another post www.gofastmopar.net W.A.R.P performance It looks like a decent front end. Would like to see if anyone has one? If they like it or not? I want to stick with torsion bars. What other choices are out there? Thanks
66 Coronet 3720lbs. 9.80 @ 138mph on a bottle
Re: W.A.R.P performance Tube Front end Anyone have one? [Re: 9second_bottle] #847128
11/06/10 11:49 AM
11/06/10 11:49 AM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
Link did not work for me.
Damon
Re: W.A.R.P performance Tube Front end Anyone have one? [Re: mopardamo] #847129
11/06/10 12:07 PM
11/06/10 12:07 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Hello,
Damon
+1
Re: W.A.R.P performance Tube Front end Anyone have one? [Re: mopardamo] #847130
11/06/10 12:09 PM
11/06/10 12:09 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
link no work-e
Re: W.A.R.P performance Tube Front end Anyone have one? [Re: 70blackfish] #847131
11/06/10 12:11 PM
11/06/10 12:11 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
Re: W.A.R.P performance Tube Front end Anyone have one? [Re: 70blackfish] #847132
11/06/10 12:25 PM
11/06/10 12:25 PM
ohio
all spooled up Offline
ohio
there kit has n lower control arms. or coil over schocks. and springs for the price of 3.100$$
go with the BEST www.bobsprofab.com
Re: W.A.R.P performance Tube Front end Anyone have one? [Re: 70blackfish] #847133
11/06/10 12:41 PM
11/06/10 12:41 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
now that looks more like a race unit than most of the over tubed ones around.Magnum force is ok for a streetcar but sucks for a race car. One day someone will address the relocation of tne upper A arms and have what the rest lack
home of the
Sox and Martin Hemi Duster
Re: W.A.R.P performance Tube Front end Anyone have one? [Re: HEMIFRED] #847134
11/06/10 04:51 PM
11/06/10 04:51 PM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
please explain fred
Re: W.A.R.P performance Tube Front end Anyone have one? [Re: j.mcconnell] #847135
11/06/10 04:57 PM
11/06/10 04:57 PM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
bobprofab here......
Re: W.A.R.P performance Tube Front end Anyone have one? [Re: SB449VALIANT] #847136
11/06/10 05:28 PM
11/06/10 05:28 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
AlterKtion here......no laps yet , but accessories and fit and finish are first rate.
Just getting the torsion bars out of the way is a giant plus.
It cost a little more than the deluxe everything included kit shown here , but I think it was worth every penny.........because it includes everything.
Re: W.A.R.P performance Tube Front end Anyone have one? [Re: 9second_bottle] #847137
11/06/10 05:29 PM
11/06/10 05:29 PM
Peoples republic of clackamas ...
atoetly Offline
atoetly  Offline
I'm running one and now that its adjusted right works great!
Re: W.A.R.P performance Tube Front end Anyone have one? [Re: atoetly] #847138
11/06/10 05:43 PM
11/06/10 05:43 PM
oregon
greendart408 Offline
oregon
Also check out overkill race cars complete k frames. This is what im going to get when I get one. Top notch and very affordable. Pics of them on yellowbullet.
Re: W.A.R.P performance Tube Front end Anyone have one? [Re: atoetly] #847139
11/06/10 06:22 PM
11/06/10 06:22 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
please exp. what you mean here if you dont mind ..i want to go with something diff. in the front but dont want to spend the bank but..
Re: W.A.R.P performance Tube Front end Anyone have one? [Re: j.mcconnell] #847140
11/06/10 07:14 PM
11/06/10 07:14 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
please explain fred
In all the units the upper A arm positioning never gets addressed The stock upper a-arm mounts have a drastic angle front to rear this causes the caster to change rapidly as the suspension travels up & down. That let's the spindle go all over the place. When corrected the entire suspension moves in much more smoothly and in unison and eliminates bump steer.
My Duster uses all factory parts and when on ground or hanging in the air has the same front end settings.,
My car has stick A arms and caster at 7
home of the
Re: W.A.R.P performance Tube Front end Anyone have one? [Re: HEMIFRED] #847141
11/06/10 07:19 PM
11/06/10 07:19 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
hay fred i remember the pics of your car with the coilovers tell us how it was done and the rack if you dont mind my be something that can be done at home with the stock parts ..thanks mike
Re: W.A.R.P performance Tube Front end Anyone have one? [Re: HEMIFRED] #847142
11/06/10 10:09 PM
11/06/10 10:09 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
please explain fred
Hotchkis has the stock style. http://www.hotchkis.net/dodge_b_e_body_geometry_corrected_tubular_upper_aarms.html
Re: W.A.R.P performance Tube Front end Anyone have one? [Re: Dos Snails] #847143
11/06/10 11:12 PM
11/06/10 11:12 PM
Price: $770.95
Re: W.A.R.P performance Tube Front end Anyone have one? [Re: greendart408] #847144
11/06/10 11:41 PM
11/06/10 11:41 PM
Colorado Springs, Colorado
Dartthunder340 Offline
Just saw one of his for the first time today. Very nice piece.
Better get inside Ma. Looks like a storm's comin'.
Re: W.A.R.P performance Tube Front end Anyone have one? [Re: earthmover] #847145
11/07/10 12:20 AM
11/07/10 12:20 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I guess it can be done with some experience.
tube K , early disc brake spindles,Kelsey ??
B body lower ball joint arm reversed, B body lower control arm,pinto rack B body upper control A arms installed on opposite sides. my lowers have eccentric bushings on the inner mounts. rotation moves the arm in and out along with spindle major fab is to rework upper a arm mounts so they are on the same plain as the t bars .parrell.the d/s spindle had been lightened
there are no brake kits around for these spindles. I am sure someting can be made to work
here's all ther pics http://s9.photobucket.com/albums/a65/HEMIFRED/DUSTER%20SUSPENSION/?start=all
home of the
Re: W.A.R.P performance Tube Front end Anyone have one? [Re: HEMIFRED] #847146
11/07/10 01:33 PM
11/07/10 01:33 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
