Upper control arm ball joint failure #847080
11/06/10 02:21 AM
11/06/10 02:21 AM
WA
GasHog72 Offline OP
GasHog72  Offline OP
WA
I'm not sure how this happened and am still trying to get it apart now. The ball joint didn't separate like I thought it did and looks like the upper control arm is no good now assuming they screw in.
Anyone had this happen before or have some experience with this?
Re: Upper control arm ball joint failure [Re: GasHog72] #847081
11/06/10 02:47 AM
11/06/10 02:47 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Yes, they screw in and that's likely due to thread failure. The factory recommended fix when one can't be torqued to spec (REAL TIGHT) is to put three or four small welds around it to keep it in place.
Re: Upper control arm ball joint failure [Re: Jim_Lusk] #847082
11/06/10 09:42 AM
11/06/10 09:42 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Doesn't seem like this type of failure is reported often here. I would think a decent used replacement arm is easy to find for most mopars. Tack welding doesn't seem to poor solution, if the threads are not wallowed out, since the threads take hardly any real axial loading, and then the most loading then I would think would be at full extension when doing General Lee ramp jumps, the most significant loading would be under braking and cornering and that would be a shear load. Tack away.
Re: Upper control arm ball joint failure [Re: GasHog72] #847083
11/06/10 09:54 AM
11/06/10 09:54 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Still, nice to see the fail-safe engineering!
Rick
Re: Upper control arm ball joint failure [Re: Rick_Ehrenberg] #847084
11/06/10 03:54 PM
11/06/10 03:54 PM
WA
GasHog72 Offline OP
GasHog72  Offline OP
WA
I'm thinking just replace with tubulars. Might as well upgrade. I have the whole suspension apart and found different issues. The outer tie rod is ready to shear off. The brake pads are cracked. Just a few things wrong. The passenger side control arm is screwy too. Taking it apart today. Good thing I sold a car, this is costing me.
