Re: Small block vs Big block
[Re: Big B]
#846652
11/05/10 06:34 PM
11/05/10 06:34 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
With your hp requirements it will be much easier to make it with a BB. 2000 hp on pump gas? Not sure... If you go twins you can run a 4" down pipe on each side, which should clear.
[Re: Keith Black®]
#846661
11/05/10 11:08 PM
11/05/10 11:08 PM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
Only thing I can say, is that to have you cake and eat it too requires substantial investment, planning, engineering requirements are huge, and you will still not get it all to the ground. 2000hp is a lot. 1500hp is a lot. 1000hp is a lot. After the dyno sheet is done we will back of the ProCharger and tune to tame it for street use. We're running everything stealth.. underhood, 2 x intercoolers, they are digitizing the whole engine bay now and are then CAD designing the whole reverse mount system for the F2, if you're after continuous duty there's a lot to do. Let me know if you want to see the fuel system design it's like a Boeing 747.
-------------------------------- Darren Beale Keith Black Racing Engines®
[Re: PHJ426]
#846666
11/06/10 12:01 AM
11/06/10 12:01 AM
Keith Black®
QLD Australia
Hopefully this file is viewable -this is the system design by Aeromotive to support 2000hp, using E85, EFI, F2-ProCharged. Note that I actually require 4 fuel rails in total and 16 injectors to support the fuel flow requirements (staged/sequential), 16 x 95 lb injectors. ProCharger will run at 15lbs @ 7000 rpm.
[Re: instigator]
#846670
11/06/10 12:28 AM
11/06/10 12:28 AM
Posts: 325 Greenville, WI
Big B
Greenville, WI
Well I do plan on installing an Alterkation front end. That should free up some space. I want to run full exhaust to make the car as quiet as possible. Maybe I will just build the Keith Black/Indy combo. Maybe go with a 540. With a big inter-cooler 2000hp is easy. The shop that builds my engine just finished a pump gas 427TT SB Chevy that made 1800 hp.
I call BS on 1800hp with 427ci on pump gas....maybe E-85 but that still would be a killer spreadport exhaust motor.
2000 hp on pump gas will be next to impossible on even a big 500+ cube motor....exempting E-85.
Todd at Goodwin Competition Racing Engines built the engine. I am going to see if I can get a copy of the dyno sheet. I thought 1800hp sounded high too, but I doubt He lied to me. They build a lot of high end engines.
