Roller lifter 440 question #846524
11/05/10 02:03 PM
11/05/10 02:03 PM
Denver
E
Explodo Offline OP
Explodo  Offline OP
E
Denver
I should probably know this, but I don't.
Is special machining required to use a roller cam and lifters in a production 440 block?
Are there any concerns that I need to know about?
'67 440 Satellite
Re: Roller lifter 440 question [Re: Explodo] #846525
11/05/10 02:22 PM
11/05/10 02:22 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
No special machining other than making sure you have enough valve spring retainer to valve guide clearance for the lift you have .
But you'll need a cam button , bronze gear oil pump drive , shorter pushrods and an adjustable rocker arm.
Re: Roller lifter 440 question [Re: JohnRR] #846526
11/05/10 02:29 PM
11/05/10 02:29 PM
Denver
E
Explodo Offline OP
Explodo  Offline OP
E
Denver
Thank you for the response.
I'm buying completely new heads, so all head/pushrod considerations will be taken care of there as they want to know cam specs to buy the heads.
Do the bronze gears last very long? I've read some that say they do and some that say they don't. I've also read that there are different alloys of bronze gears. Who makes a good one for a 440 then?
'67 440 Satellite
Re: Roller lifter 440 question [Re: Explodo] #846527
11/05/10 02:31 PM
11/05/10 02:31 PM
JohnRR Offline
JohnRR  Offline
The bronze gear wears, something has to be soft because of the material the cam core is made of and the gear is the sacrificial part, I have no idea who makes the best .
Re: Roller lifter 440 question [Re: JohnRR] #846528
11/05/10 02:44 PM
11/05/10 02:44 PM
Denver
E
Explodo Offline OP
Explodo  Offline OP
E
Denver
Does anyone make 440 roller cams with the cast iron gears pressed on?
'67 440 Satellite
Re: Roller lifter 440 question [Re: Explodo] #846529
11/05/10 02:48 PM
11/05/10 02:48 PM
JohnRR Offline
JohnRR  Offline
Not that I have heard of , if it was a chevy or a ford yes , mopar is the red headed step child of the aftermarket .
Re: Roller lifter 440 question [Re: Explodo] #846530
11/05/10 04:54 PM
11/05/10 04:54 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Problem with the BB Mopar is the oil/distributor drive gear is at the front. In small and big block Chevys as well as SB Mopars with the drive gear at the back, it is a relatively simple matter to press on a gear because it can be made to fit over the rear journal. With the larger journals at the front of camshafts the inside diameter required for the drive gear would be larger than the gear itself.
Re: Roller lifter 440 question [Re: Explodo] #846531
11/08/10 08:43 AM
11/08/10 08:43 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I've found that Milodon's works pretty good and last for a few years. Make sure you keep the cam end play to a minimum (no more that .005"). Try not to run excessive oil pressure.
