What the best harmonic balancer puller you can buy? #846249
11/04/10 11:52 PM
11/04/10 11:52 PM
Confusion
Dodger440 Offline OP
Confusion
Just like the title says, I am looking to buy a top quality, heavy duty, harmonic balancer puller. I just got done fighting with a Fluidampr that was very tightly pressed onto a crankshaft. I'm sure a good quality puller would have made it much easier. Do any of them have a thrust bearing to help take some of the load while turning the bolt? Any input is appreciated!
Re: What the best harmonic balancer puller you can buy? [Re: Dodger440] #846250
11/04/10 11:59 PM
11/04/10 11:59 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
The prob you have .. is the damper was not fitted right. And the BEST HB puller ? .. if the HB was fitted right ...a cheapy should be perfectly OK.
T bearing ? ... it not affected at all in the removal of the HB process.
Re: What the best harmonic balancer puller you can buy? [Re: Dodger440] #846251
11/05/10 12:04 AM
11/05/10 12:04 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
Summit sells a nice one with a bearing that goes against the bolt so when you turn the puller the pressure is on the bearing and not the balancer face. Works great and is a universal kit.
