number matching motor #846185
11/04/10 11:19 PM
11/04/10 11:19 PM
Illinois
Craig61 Offline OP
Craig61  Offline OP
Illinois
How can you tell if the motor is number matching on a 1965 Plymouth Belvedere? Also how much does it hurt the value of 1965 Belvedere if it has a 440 in it instead of the 383 that it was born with?
Re: number matching motor [Re: Craig61] #846186
11/04/10 11:24 PM
11/04/10 11:24 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
My opinion is that if the car is otherwise perfectly restored BUT has a different size engine than it was built with, the difference in value could be up to 25%. If several changes were made with the car such as a color change, added or removed A/C, bigger wheels and tires and so on, I doubt that a different motor matters. The horse is already out of the barn by then.
Re: number matching motor [Re: Craig61] #846187
11/05/10 12:45 AM
11/05/10 12:45 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
There really is no way other than to check the assembly date of the engine and it should be very close to or just before the cars SPD .
