Hughes Valley Pan #846157
11/04/10 11:07 PM
11/04/10 11:07 PM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
Has anybody tried these? Could these help prevent a vacuum leak with the silicone embossed gaskets?
Re: Hughes Valley Pan [Re: Moe] #846158
11/04/10 11:15 PM
11/04/10 11:15 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
I would like to find a concave stocker-type ... so you could just plain gaskets on the intake and head surfaces.
Re: Hughes Valley Pan *DELETED* [Re: dOc …] #846159
11/04/10 11:27 PM
11/04/10 11:27 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
Post deleted by rhad
Re: Hughes Valley Pan [Re: rhad] #846160
11/05/10 12:04 AM
11/05/10 12:04 AM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
I have used the Hughes pan with my Stage VI heads. Used grey Right Stuff, ran a bead along cylinder head edges and front and rear block area. Used the OE 3 bolt braces and let sit for 24 hours with no leaks...Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: Hughes Valley Pan [Re: Wicked49670dart] #846161
11/05/10 09:27 AM
11/05/10 09:27 AM
scratchnfotraction Offline
does that work with stock heads?
just use sealer along the head and ends
so you would use the paper gaskets instead of the stock vally pan which is the gasket correct?
I will be swapping intakes soon and never did a BB intake swap yet
this looks good,and looks like intake changes will be simple
Re: Hughes Valley Pan [Re: scratchnfotraction] #846162
11/05/10 11:08 AM
11/05/10 11:08 AM
ILL
Greentween Offline
Greentween  Offline
ILL
dosent work with bb 516 heads, it leaks. The intake surfaces on the 516's have knotches in them so there is no sealing surface for the intake gasket where those knotches are.
Re: Hughes Valley Pan [Re: Greentween] #846163
11/19/10 11:22 PM
11/19/10 11:22 PM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
Hughes got back to me on these and said one cylinder has to be loosed for these to work.
Re: Hughes Valley Pan [Re: Moe] #846164
11/20/10 12:16 AM
11/20/10 12:16 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Hughes makes a two piece valley pan that is way better than the one piece and is only about $15.00 more. That's what I put on my new engine for Da Beast I. I used the right stuff to seal it. I haven't run the engine yet so I can't comment on leakage.
Re: Hughes Valley Pan [Re: Moe] #846165
11/20/10 03:03 AM
11/20/10 03:03 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
You won't be able to use a manifold with a low-hanging heat crossover; it will be high-centered.
Re: Hughes Valley Pan [Re: dOc …] #846166
11/20/10 03:10 AM
11/20/10 03:10 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
If you have aluminum heads you can cut the off the port sections of the 1214/1215 Fel Pros.
Re: Hughes Valley Pan [Re: Dabee] #846167
11/29/10 06:28 PM
11/29/10 06:28 PM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
You are correct. Thanks for the tip. The 2 piece can be used W/O loosening a head. The intake manifold gaskets go on dry also.
https://hughesengines.secure.nharmony.co...mp;partid=24085
