support bearing for crank & blower drive? #845192
11/03/10 05:48 PM
11/03/10 05:48 PM
QLD Australia
Keith Black® Offline OP
QLD Australia
Would any additional support be required (i.e. extra bearing) at the nose of the crank for a Hemi running an F2-ProCharger (max 15lbs boost).
I have a billet dual-key crank & we're making up front drive system for accessories and the blower. The engineer has made support bearings for other apps (like GM/Ford etc). I would think that the Hemi is pretty strong in this area. What do the top fuel/pro mod guys run in terms of support?
..opinions and ideas appreciated!
Darren Beale
Keith Black Racing Engines®
Re: support bearing for crank & blower drive? [Re: Keith Black®] #845193
11/03/10 06:29 PM
11/03/10 06:29 PM
QLD Australia
QLD Australia
any ideas..?...
apparently there IS a need:
http://www.goodvibesracing.com/moreinfo.php
Darren Beale
Re: support bearing for crank & blower drive? [Re: Keith Black®] #845194
11/03/10 06:50 PM
11/03/10 06:50 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Blown Hemis w/big boost(rotor type blowers) use a front crank suport. Otherwise they crack in the #1 throw. Dont know how much load the centrifical types put on the crank. I suspect that not nearly as much due to it being baisicaly a gear driven turbo. So the main shaft requires less torque to rotate. Speed is generated by a gearset in the blower assembly and boost is controlled by bleed off. whereas speed/boost is all belt/Pulley dependant on a rotor type blower.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: support bearing for crank & blower drive? [Re: W.I.N. Racing] #845195
11/03/10 08:02 PM
11/03/10 08:02 PM
QLD Australia
QLD Australia
thanks.., those were my thoughts too.
Would be interesting to know the loading variation on the crank (or parasitic losses) as a A vs B comparison between CD & centrifugal blowers.
I think I could only justify this approach if it adds some longevity, durability or reduces maintenance in the setup.
Be good to hear from anyone with a bearing setup and their experience and why/why not etc.
Darren Beale
Re: support bearing for crank & blower drive? [Re: Keith Black®] #845196
11/03/10 08:57 PM
11/03/10 08:57 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I ran my 547 hemi with a f2 all season without bearing/crank issues.
14lbs of boost on my motor.
IMO it's not enough boost to stress the crank.
You should cal steve morris if your really concerned.
