Blown Hemis w/big boost(rotor type blowers) use a front crank suport. Otherwise they crack in the #1 throw. Dont know how much load the centrifical types put on the crank. I suspect that not nearly as much due to it being baisicaly a gear driven turbo. So the main shaft requires less torque to rotate. Speed is generated by a gearset in the blower assembly and boost is controlled by bleed off. whereas speed/boost is all belt/Pulley dependant on a rotor type blower.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
