Cuda grille #844934
11/03/10 12:15 AM
11/03/10 12:15 AM
desomod Offline OP
desomod  Offline OP
I am looking at a '72 Cuda and would like to change out the grille for a '70 or '71. I have a repo "premere plastics" '71 and the graters (no stainless trim)that I can use though it seems to be pretty fragile (poor quality). My question is, at this point, is it easier (less expensive) for me to change to the 70 or 71? I know the 70 uses it's own header panel and the 71 on are the same, and that the 71 has the quad headlamps and seperate parking/turn signals so I would have to get them and the headlight buckets (and the stainless). On the 70, I would have to get the entire grille, at least it is all available and good quality.
Re: Cuda grille [Re: desomod] #844935
11/03/10 12:39 AM
11/03/10 12:39 AM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Id clone it into a 70. You can get a quality repro grille from B&EA, they are NICE. And you fenders will work without any mods.
