Cam installed centerline question #844365
11/02/10 05:40 PM
11/02/10 05:40 PM
Jacksonville, Fl
426runner Offline OP
Jacksonville, Fl
What would be the affect on an engine if the cam was installed at 105 c/l when the card said it was meant for 108 deg c/l?
Later, Sandy '70 HEMI Road Runner B5/B5, 4 spd "Sandy's Garage" on Facebook
Re: Cam installed centerline question [Re: 426runner] #844366
11/02/10 06:09 PM
11/02/10 06:09 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
it will run better...lol
you are 3 degrees advanced...advancing the cam with help the low end performance...increase cylinder pressure by closing the instake valve sooner..
Advancing the camshaft means that you are starting the opening and closing process sooner in the cycle. It generally improves low-speed torque and mid-range power while sacrificing top-end hp. Conversely, retarding the cam detracts from low- and mid-range power in order to help top-end power. Generally, moving a camshaft a couple of degrees will not make dramatic changes to the engine's power curve
Tony
70 AARCuda Vitamin C
Re: Cam installed centerline question [Re: 426runner] #844367
11/02/10 06:16 PM
11/02/10 06:16 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Your engine will be retarded !
The intake valve opens later and closes later. Since it closes ABDC that's a hair less compression the motor will make. Likewise the exhaust valve will open sooner, releasing combustion pressure sooner. All this equates to a loss of power.
Re: Cam installed centerline question [Re: Stanton] #844368
11/02/10 06:31 PM
11/02/10 06:31 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Is this a joke? Retarded?
Re: Cam installed centerline question [Re: Stanton] #844369
11/02/10 09:00 PM
11/02/10 09:00 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
You have it backwards. If the intake valve reaches peak lift earlier at 105* ATDC vs 108* ATDC
Then it is indeed advanced and not retarded.
For the OP, if thats where your at. Thats not a bad ICL area. IMO 101* to 106* for alot of engine combos is a good general ICL. mike
Re: Cam installed centerline question [Re: Stanton] #844370
11/02/10 09:32 PM
11/02/10 09:32 PM
UK
602heavy Offline
602heavy  Offline
UK
Your engine will be ADVANCED.
The intake valve opens earlier and in turn will close earlier. Since it closes ABDC that's a hair more compression the motor will make. Likewise the exhaust valve will open sooner, releasing combustion pressure sooner. All this equates to a loss of power.
This is what you meant to say?
On a serious note.......i agree , ex valve opening earlier could net a loss in power dependant on compression ratio.
Re: Cam installed centerline question [Re: 426runner] #844371
11/02/10 09:54 PM
11/02/10 09:54 PM
yes it's confusing as a smaller # ie 105 vs 108 means sooner (advanced) as 5 o'clock is sooner than 8 o'clock. the intake valve reaches peak lift at 105 deg past TDC compression (which is sooner) than if it reached it at 108 deg past TDC compression (& therefore closes sooner). As said it shifts the power band lower & reduces the valve to piston of either the intake or ex valve (I forget which one). Cams I've advanced (street) which you'd be doing (to 105) have always benefitted from it (more torque)
Re: Cam installed centerline question [Re: RapidRobert] #844372
11/02/10 10:02 PM
11/02/10 10:02 PM
UK
602heavy Offline
602heavy  Offline
UK
yes it's confusing as a smaller # ie 105 vs 108 means sooner (advanced) as 5 o'clock is sooner than 8 o'clock. the intake valve reaches peak lift at 105 deg past TDC INDUCTION stroke (which is sooner) than if it reached it at 108 deg past TDC INDUCTION stroke (& therefore closes sooner). As said it shifts the power band lower & reduces the valve to piston of either the intake or ex valve (I forget which one). Cams I've advanced (street) which you'd be doing (to 105) have always benefitted from it (more torque)
Re: Cam installed centerline question [Re: 426runner] #844373
11/03/10 08:55 AM
11/03/10 08:55 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
Another thing to keep in mind is many cams are ground with advance built into them, that is when installed dot to dot. So if that cam recomended 108 centerline is combined with a 112 degree lobe sepration angle then there is 4 degrees of advance already in the cam. When people refer to installing the cam straight up it means that to your cam the centerline would be 112 (straight up is not dot to dot as many folks assume). The confusing thing here is centerline is expressed in crank degrees and lobe seperation is expressed in cam degrees. The crank turns twice for each revolution of the cam so to convert lobe sepration to crank degrees double it and divided by two for the straight up centerline or straight up centerline = lobe seperation angle.
If you install it at a 105 then you will be 7 degrees advanced (as a comparision one tooth off on the cam sproket is 9 degrees on a 40 tooth cam sprocket). The typical rule of thumb is if you need to advance/retard the cam by more than 5 degrees you selected the wrong cam.
Advancing the cam will tend to improve low/mid range power and retarding it will improve high end power.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: Cam installed centerline question [Re: dgc333] #844374
11/03/10 02:49 PM
11/03/10 02:49 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
How long has it been since you had a basic math class?
Re: Cam installed centerline question [Re: GomangoCuda] #844375
11/03/10 03:13 PM
11/03/10 03:13 PM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
Heres a somewhat related question about cam timing...
If I have an adjustable timing chain with multiple keyways on the crankshaft gear, and they are marked 0, +1, +2, +3, -1, -2, -3, etc...
Lets say I have a lobe separation angle of 106*
If I set the timing gear so that it is in the +2 slot, does that mean I am advancing the camshaft 2 degrees so that its now 104* or does that mean that I am adding 2 degrees to the 106* number? 106+2=108?
Re: Cam installed centerline question [Re: chache876] #844376
11/03/10 03:40 PM
11/03/10 03:40 PM
UK
602heavy Offline
602heavy  Offline
UK
+ advance
- retard
'lining up the dots' is a no no , the only accurate way would be to use a degree wheel , some of those crank/cam gears are not always accurate.
Re: Cam installed centerline question [Re: GomangoCuda] #844377
11/04/10 03:24 PM
11/04/10 03:24 PM
Mass
dgc333 Offline
dgc333  Offline
Mass
I know exactly what I said, in my 30+ years as an engineer I have found that sometimes it helps to make things clear to state the obvious. I could have just said; "straight up centerline = lobe seperation angle" but I wonder how many more folks will remember why that is true because I added the silly little math expression.
Re: Cam installed centerline question [Re: dgc333] #844378
11/04/10 05:27 PM
11/04/10 05:27 PM
I'm w you here as cam theory is (sort of) Greek to me & I need it (the obvious) spelled out so I can grasp it.
Re: Cam installed centerline question [Re: chache876] #844379
11/04/10 06:51 PM
11/04/10 06:51 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Lobe seperation angle is not the installed centerline. Lobe sep angle is ground into the cam and cannot be changed. The installed centerline is where the cam grinder reccomends to put the intake centerline for best performannce. Ron
Re: Cam installed centerline question [Re: 426runner] #844380
11/11/10 10:27 AM
11/11/10 10:27 AM
Jacksonville, Fl
Jacksonville, Fl
Another related question... It is always recomended to check the installation of the cam for the proper centerline as called for by the manufacturer. Most all write-ups or videos that show the process end up with the CL coming out correct. Mine didn't. My installation calculated out to 105 instead of 108 like the card said it should. Why would this happen? What factors could contribute to the cam not being as the manufacturer says it should be out of the box? And yes, there were 2 of us there during the degreeing process and we did it over and over and came up with the same 105 every time.
Re: Cam installed centerline question [Re: 426runner] #844381
11/11/10 02:33 PM
11/11/10 02:33 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Timing chain set variances, cam being ground slightly off, could be a couple issues to change the installed centerline.
Re: Cam installed centerline question [Re: RobX4406] #844382
11/11/10 02:52 PM
11/11/10 02:52 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
It's called the stacking effect. the key way on the crank may be of a bit. the key way in the bottom gear may be off a bit, the dowel hole in the top gear may be off a bit and the dowel placement in the cam may be off a bit as these things are less than perfect.
sometimes it stacks up to 10 or more degree's off.
I would leave your cam where it is you will like it with a tad more advance!
