71-72 speedo switch 3438494 #844309
11/02/10 03:04 PM
11/02/10 03:04 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Does anybody have any info on how this switch works? Just the switch itself. Does it turn on or off at a specific speed? Does it send a continuous signal based upon the rpm it gets from the transmission?
- Stu Harmon
Re: 71-72 speedo switch 3438494 [Re: feets] #844310
11/02/10 04:49 PM
11/02/10 04:49 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
That's part of the NOX system, it supplies a ground signal to the control module when the road speed hits approximately 40 mph. There is also a cowl-mounted temp sensor that's part of the NOX system which retards the spark at speed.
Re: 71-72 speedo switch 3438494 [Re: John_Kunkel] #844311
11/02/10 04:53 PM
11/02/10 04:53 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
40 mph isn't a bad. That's fast enough for converter lockup. That switch could toss the ground to a relay.
- Stu Harmon
Re: 71-72 speedo switch 3438494 [Re: feets] #844312
11/02/10 04:55 PM
11/02/10 04:55 PM
Rio Linda, CA
Rio Linda, CA
Yep, that's why I grab every one I find.
