360 Magnum balancing ?
#844118
11/02/10 08:39 AM
11/02/10 08:39 AM
Posts: 22 IL.
prodak87
IL.
Re: 360 Magnum balancing ?
[Re: Andrewh]
#844120
11/02/10 12:00 PM
11/02/10 12:00 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Just use the flex plate from the R/T it already has the weight on it for the magnum. If you do that be sure to knock off the 360 weight on the converter. You may have to elongate one bolt hole but it works great.
[Re: patrick]
#844122
11/02/10 12:53 PM
11/02/10 12:53 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
but wasn't the magnum 360 only available with 727 based trannies? (46RH/RE)?
No, i have mine hooked up to a 904, i just used the 360 magnum flexplate with the weights, just longate one of the holes & its a fit.
[Re: patrick]
#844125
11/02/10 04:40 PM
11/02/10 04:40 PM
joedust451
super gas
super gas
Branson, Mo.
so the OEM weighted flexplate will work with a 904 or 727?
Yep, speaking for the 904 anyway, i'm sure the 727 would be the same, some magnums came with the weights on the converter, just need the ones that had the weights on the flexplate.
[Re: joedust451]
#844126
11/02/10 05:39 PM
11/02/10 05:39 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
but what I'm saying is the 360 mag was never available behind a 904 based tranny (42RH/RE), and I _thought_ the bolt circle on a 904's converter is a smaller diameter than a 727's converter.....if it's not, B&M makes a magnum weighted flexplate for a 727
[Re: patrick]
#844127
11/02/10 05:54 PM
11/02/10 05:54 PM
joedust451
super gas
super gas
Branson, Mo.
For whatever its worth, I'm not sure what tranny was behind this 360 magnum flexplate, but not only did my "stock" 904 converter bolt up to it, so did the PTC i bought, another thing i did (& it worked out great) is open up the flexplate holes to except the 7/16" bolts, I don't know what to tell you, other then you "CAN" bolt up a 904 converter, & B&M no longer makes the flexplate for the 904/360 magnum conversion.
[Re: patrick]
#844130
11/03/10 09:52 PM
11/03/10 09:52 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
good info gdonovan!
Your welcome!
The starter banging into the tone wheel caught me with my pants down but I'm not one to be stopped for long.
