Re: A518 speedo drive question
[Re: way2fast]
#844070
11/02/10 04:59 PM
11/02/10 04:59 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The 518 probably has the same speedo pinion adapter as the 3-speeds, the distance sensor just screws on to the same thread that the cable used to.
[Re: John_Kunkel]
#844071
11/02/10 05:23 PM
11/02/10 05:23 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
My 92 D250 Cummins has the speed sensor with a wire and a cable attachment. The speedo is still driven the old fashioned way but the computer wants to see the speed too.
[Re: feets]
#844074
11/02/10 08:01 PM
11/02/10 08:01 PM
Posts: 12,237 Looking for a way out of Middl...
IMGTX
Just an FYI. They used a 2 wire inline one like you are talking about for several years but the newer ones use a 3 wire one that does not have a cable pass through. If you are doing a ~92 or later trans and using the ECU to control the trans and need a cable then you need another adapter.
If you are using hydraulic & vaccume controllers to work the Lockup & overdrive like most people do then you don't need the speed sensor.
[Re: IMGTX]
#844075
11/02/10 09:30 PM
11/02/10 09:30 PM
Posts: 4,744 Florida
BDW
