Adjusting Cal Trac bars ?? #843550
11/01/10 04:19 PM
11/01/10 04:19 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
I bought a bracket car a while back that had a set of cal trac bars and it worked good. We are adding a little more power as we go along. Now it lifts the car so much that it unloads the tires. How can i stop this. Now the bars are in the bottom holes on both ends that makes the bars almost level. Any help Thanks
Re: Adjusting Cal Trac babs ?? [Re: bobs69] #843551
11/01/10 04:26 PM
11/01/10 04:26 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
shocks!
Re: Adjusting Cal Trac babs ?? [Re: Randy..] #843552
11/01/10 06:19 PM
11/01/10 06:19 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
shocks!
Re: Adjusting Cal Trac babs ?? [Re: Twin Turbo Mower] #843553
11/01/10 06:47 PM
11/01/10 06:47 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
go to yellowbullet.com look under stock susp. i think it under that name? there is a good amount of info on cals.brad
Re: Adjusting Cal Trac babs ?? [Re: a493demon] #843554
11/18/10 09:40 PM
11/18/10 09:40 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
We added new adjustable shocks and 50 pounds of weight in the trunk. Everything got better 60ft times and eighth mile e-t and mile per hour. Thanks for the help!!
