Braking on A Body Different Sizes #84332
07/05/08 12:32 PM
07/05/08 12:32 PM
Not2farfromNashville, TN
Rug_Trucker Offline OP
3 to choose from.
Stock 66 B body rear with stock brakes.
Stock 71 A body 8 3/4 brakes
Or 3x11 C body(?) drums?
I have all the stuff to do the BBP front disc conversion.
Should I buy the Eberg small wheel cylinders to run with the 3"ers?
What does it take to swap to the 11.75 on the front?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Braking on A Body Different Sizes [Re: Rug_Trucker] #84333
07/05/08 04:10 PM
07/05/08 04:10 PM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
I have a 63 B body rear end in my 71 Duster and 11.75 front discs with a manual master cylinder. Nice braking power. Got the 11.75 discs from e-berg. 11.75 caliper brackets off e-bay and manual master cylinder from Magnum Performance.
Re: Braking on A Body Different Sizes [Re: dmerc] #84334
07/05/08 04:25 PM
07/05/08 04:25 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
You need a little more than 4.5 backspacing rear rims when running the pre 63-67 width rears. Unless you are running real narrow tires.
The 11x3 aren't neccessary and just weigh things down.
Just get a the right pin or slider caliper adapter to get to 11.75 disks
Re: Braking on A Body Different Sizes [Re: autoxcuda] #84335
07/06/08 09:24 AM
07/06/08 09:24 AM
That isn't on the spindle?
Re: Braking on A Body Different Sizes [Re: Rug_Trucker] #84336
07/06/08 09:26 AM
07/06/08 09:26 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
the spindle is the same between the 2 brake sizes , the caliper adaptor unbolts from the spindle and thats the difference between the 2 , uses the same caliper .
