CH4B Users... #84299
07/05/08 11:20 AM
07/05/08 11:20 AM
Farmland, IN
Ludington1 Offline OP
Farmland, IN
I picked up a used CH4B intake this week, and I was checking it out yesterday. On the passenger side of the intake in the heat-riser area there is a small hole down between the runners, maybe 1/8" in diameter. Is this open to anything on the inside, i.e. need plugged to prevent a vacuum leak?
The one I have here is a little different than the one pictured, but the yellow arrow shows the area I am asking about. Mine does NOT have the flat machined pad there with the two holes in it, just the runner for the heat passage and the small hole is there.
Thanks,
Darren
Re: CH4B Users... [Re: Ludington1] #84300
07/05/08 11:25 AM
07/05/08 11:25 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
i have one but its at the machine shop getting the head gasket surfaces planed after i welded up a crack in the heat riser but i don't think it goes anywhere , you could for piece of mind just tap the hole and put an allen set screw in it .
Re: CH4B Users... [Re: Ludington1] #84301
07/05/08 02:14 PM
07/05/08 02:14 PM
I'm running that intake on my 59 Coronet; it has the flat pad like the one in your picture. On that version, at least, the hole doesn't go anywhere and doesn't need to be plugged.
Re: CH4B Users... #84302
07/05/08 02:27 PM
07/05/08 02:27 PM
Farmland, IN
Farmland, IN
Thanks guys, I guess there at least 2 versions of the CH4B out there. I will post a pic and try to see if the hole is threaded already.
Darren
Re: CH4B Users... [Re: Ludington1] #84303
07/05/08 02:36 PM
07/05/08 02:36 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Is this the hole you are referring to? Its a blank hole....
PS---my CH4B doesn't have that pad either
1MYTGTX
Re: CH4B Users... [Re: 1MYTGTX] #84304
07/05/08 04:19 PM
07/05/08 04:19 PM
Farmland, IN
Farmland, IN
Yes, that's it! Thank you, any idea why the hole is there?
Darren
Re: CH4B Users... [Re: Ludington1] #84305
07/05/08 04:25 PM
07/05/08 04:25 PM
JohnRR Offline
JohnRR  Offline
Darren
for some sort of choke thermostat assembly that you can't get anymore
Re: CH4B Users... [Re: JohnRR] #84306
07/05/08 05:14 PM
07/05/08 05:14 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
its for heat to a holley intergal choke. back then the holley 3310 was the common universal performance carb and it had a choke that needed a heat source.
Re: CH4B Users... [Re: lewtot184] #84307
07/06/08 09:25 AM
07/06/08 09:25 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
don't forget to mill down the center plentum divider about 1/4" helps air flow thru out the intake
Re: CH4B Users... [Re: 1MYTGTX] #84308
07/06/08 02:46 PM
07/06/08 02:46 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Mine's exactly like that also, but mine also has the same size hole on the bottom of the intake in the heat crossover passage and if you put air to the hole on the bottom it will blow out that little hole on mine. Weird.....I blocked my heat cross over up on both sides with the valley tray though.
By the way, guys that are running them.......you like them? The intake that is?
Moparlee
Re: CH4B Users... [Re: Robbins] #84309
07/07/08 11:06 AM
07/07/08 11:06 AM
Upper Midwest
Black_Sheep Offline
Black_Sheep  Offline
Upper Midwest
I like it! The CH4B makes decent power and it's low enough to work with the factory Air Grabber set-up...
'69 Plymouth GTX
See you on the street...
Re: CH4B Users... [Re: Black_Sheep] #84310
07/07/08 01:23 PM
07/07/08 01:23 PM
JohnRR Offline
JohnRR  Offline
thats interesting , did you have to do anything to the air cleaner height ? member NASBackyard put one on the 440 in his 69 RR on my recomendation and the air cleaner hit his hood ???
Re: CH4B Users... [Re: JohnRR] #84311
07/07/08 05:11 PM
07/07/08 05:11 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
It will work fine w/ a factory air cleaner. I ran one w/ a 1/2 spacer in a 67 GTX and it worked fine.
Re: CH4B Users... [Re: Mr.Yuck] #84312
07/07/08 06:01 PM
07/07/08 06:01 PM
Farmland, IN
Farmland, IN
I got mine installed... with my Holley Street Avenger 770 and a 1/3" spacer I have it under the hood on my 69 R/T with Ramcharger hood. I am using a drop-base bottom to from Steve (Torred4speed), I will try it this weekend with the steel base and see how close it is.
Darren
Re: CH4B Users... [Re: Mr.Yuck] #84313
07/07/08 06:09 PM
07/07/08 06:09 PM
JohnRR Offline
JohnRR  Offline
did you have a 69 440 air grabber air cleaner assembly on your 67 gtx ?
Re: CH4B Users... [Re: Robbins] #84314
07/07/08 10:13 PM
07/07/08 10:13 PM
Central NC
gch Offline
gch  Offline
Central NC
I have one on my 496 in my c body.It runs great with it.More bottom end than my sd(heavy car)and still pulls hard on the top end.I shift around 5800 but the motor will pull well past 6000 so the intake can breathe.
Re: CH4B Users... [Re: Black_Sheep] #84315
07/07/08 11:20 PM
07/07/08 11:20 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
Exactly! It is nice intake and pulls just as well as the edlebrock performer, plus its low enough to sit under a stock hood. Also NO you don't need to plug that hole, it goes nowhere.
Mike
1969 Dodge Dart Swinger
Re: CH4B Users... [Re: JohnRR] #84316
07/08/08 08:54 AM
07/08/08 08:54 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
donkey...John, not but it's a flat hood, so I'd think it'd fit under a 69 RR
Re: CH4B Users... [Re: Mr.Yuck] #84317
07/08/08 09:07 AM
07/08/08 09:07 AM
JohnRR Offline
JohnRR  Offline
donkey ...
A stock dual snorkel air cleaner that is not used with an AIR GRABBER setup doesn't sit as high as an air grabber air cleaner , so ASSuMEing its going clear the hood is not really a good idea , as I stated I ASSuMEd it would clear and a member now has a dent in his hood because of it .
Re: CH4B Users... [Re: JohnRR] #84318
07/08/08 09:44 AM
07/08/08 09:44 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Well I still think it should fit.
