Getting rust off Crank #842603
10/31/10 01:26 AM
10/31/10 01:26 AM
Brandon, Ms
cornet684me Offline OP
Brandon, Ms
i just bought a motor that has been rebuilt and sitting on a pallet under plastic for 2years, everything looks great has been oiled and rotated regularly, the only rust i visablty see is on the front of the crank where the crank damper goes, how can i get this rust off, i was thinking about taking some 600 grit and lightly sanding with some wd40 oil?
Re: Getting rust off Crank [Re: cornet684me] #842604
10/31/10 01:52 AM
10/31/10 01:52 AM
steel wool pad
Re: Getting rust off Crank [Re: RapidRobert] #842605
10/31/10 01:56 AM
10/31/10 01:56 AM
Brandon, Ms
Brandon, Ms
do i put some oil on it and use the triple 000fine?
Re: Getting rust off Crank [Re: cornet684me] #842606
10/31/10 01:59 AM
10/31/10 01:59 AM
I'd use solvent & not sure of the grit but the finer the better as long as it'll cut what your trying to remove (the rust in this case)
Re: Getting rust off Crank [Re: RapidRobert] #842607
10/31/10 02:12 AM
10/31/10 02:12 AM
Brandon, Ms
Brandon, Ms
i will try this tommorrow,
thanks
Re: Getting rust off Crank [Re: cornet684me] #842608
10/31/10 03:02 AM
10/31/10 03:02 AM
Montana
Y
Yancy Derringer Offline
Y
Montana
You don't need to worry about using such fine paper. Even, I donnooo, 120g should be fine. You don't need to get it absolutely "chrome," just clean off the rust so you can get the damper on, and there's no debri that'll make it into the pan
Re: Getting rust off Crank [Re: cornet684me] #842609
10/31/10 03:24 AM
10/31/10 03:24 AM
Everett, WA
K
kimphall Offline
kimphall  Offline
K
Everett, WA
Have you tried CLR or Naval Jelly? They work really well without the concern for removing material. Let it sit, then fine steel wool it to clean up the surface.
Re: Getting rust off Crank [Re: cornet684me] #842610
10/31/10 03:31 AM
10/31/10 03:31 AM
grab a steel wool pad w the soap in it from your kitchen & dip it in solvent & it'll be rust free in no time
Re: Getting rust off Crank [Re: RapidRobert] #842611
10/31/10 10:11 AM
10/31/10 10:11 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
or some crocus cloth. This is an area that isn't real particular. Just so that the damper slides on slightly snug, it is not a press fit.
