Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: Dean_Kuzluzski] #842447
11/01/10 10:49 AM
11/01/10 10:49 AM
Sask, Can.
72demon416 Offline OP
Sask, Can.
Thanks guys!- that's some great info to try- just like you said dean- there is NO gear clash- just like hitting a wall. Once I get it figured out I'll post it up.
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: 72demon416] #842448
11/01/10 09:01 PM
11/01/10 09:01 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I had a 73 b-body 4-speed that wouldn't shift into 2nd @ high rpm either but I did figure out that the reverse lever was moving and would lock 1-2 out during gear change because of the interlock side cover so I put a spring on it that would hold it back which worked fine, it musta had the ball & detent problem but never did investigate it before I sold it.
Mitch
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: scatpacktom] #842449
11/01/10 11:04 PM
11/01/10 11:04 PM
Sask, Can.
Sask, Can.
Well I should have asked the obvious questions before...how will I know if the detent ball has fallen out? (I suppose the reverse lights would not work... ) pull the side cover off and fish for it? or is there a better way?
I'm assuming that it gets reinstalled through the side cover opening as well?
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: 72demon416] #842450
11/01/10 11:17 PM
11/01/10 11:17 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
No, the ball is located at the bottom of the the large hex under just the reverse light switch. You can fish for it but I like to take off the reverse rod and feel the detent snap in. Course if you don't have a feel for it you might miss it as the spring is still there.
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: scatpacktom] #842451
11/02/10 12:47 AM
11/02/10 12:47 AM
Sask, Can.
Sask, Can.
Ok- thanks Tom. I'll give it a whirl this weekend.
Rick
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: 72demon416] #842452
11/02/10 11:08 AM
11/02/10 11:08 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Just undo the rev. rod and shift it into reverse by hand. If the ball fell out, there's no detent and it will be QUITE obvious.
I'd be surprised if that actually has happened. If there's no detent for reverse there'd be other clues, like when you try to shift into reverse.
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: Dean_Kuzluzski] #842453
11/02/10 11:38 AM
11/02/10 11:38 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Exactly what would those other clues be Dean?
I can't tell you how many people this has happened to, none of them thought it was it either. Don't get me wrong alot of times it is the syncro and it probably is in this case too, but you sure wouldn't pull the trans if you didn't have to. Keep in mind when the ball pops out the spring remains.
The ONLY clue the ball has popped out is it won't shift into second at speed.
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: scatpacktom] #842454
11/02/10 12:03 PM
11/02/10 12:03 PM
Holly/MI
Holly/MI
Well, I just got done assembling an 833 a few weeks ago. And on the bench, there's a huge difference in how the "shift feel" is when that ball is not loaded against the lever. I'm thinking it's safe to assume anyone would feel that when shifting from the drivers seat. Maybe not, my mistake.
Not to mention, that detent is there for retention of the lever to stay in neutral. I also would think that tend to walk and create a difficulty in finding reverse. And possible nonsychro "gear clatter".
But, as I said, it can be checked out w/o pulling the sidecover. Undo the rod and see how it feels. When the jury comes back we'll see.
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: Dean_Kuzluzski] #842455
11/02/10 12:15 PM
11/02/10 12:15 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I assure you... you can't tell from the drivers seat.
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: scatpacktom] #842456
11/02/10 01:03 PM
11/02/10 01:03 PM
Holly/MI
Holly/MI
OK.
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: Dean_Kuzluzski] #842457
11/02/10 01:29 PM
11/02/10 01:29 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Surprised noone mentioned dialing in the bell. If an engine has been rebuilt, or the car is being built to shift fast for any reason, you ned to indicate the bellhousing and make sure it lines up properly with the crank centerline. It's standard practice and the symptoms are most of what everyone is describing. I've not heard of sticky synchros or ever seen them but there's more i haven't seen than I've seen...lol. But I have seen misalignment by as much as .030" that does cause the input to put pressure on the mainshaft and geartrain that makes fast shfting impossible or difficult.
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: moper] #842458
11/02/10 04:35 PM
11/02/10 04:35 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I was making some passes and missed a powershift into 2'nd on one of my last runs- I'm assuming I damaged something. It use to shift perfect under high rpm...
I was going to mention it but re-read that it shifted good at on time. Even though the engine was rebuilt I assumed that the same block and bell housing were used. If not, then indeed indexing could be a potential problem. But in most cases all shifts would be affected, not just a first to second. When you miss a shift, most likely the dog teeth get boggered up. Once they loose that sharp edge, it gets harder and harder to hit the gears.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: 68LAR] #842459
11/02/10 05:11 PM
11/02/10 05:11 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
One more thing to look at would be ALL the linkage with special attention to the shift shaft lever. I had one crack from one of the corners and it would open up when I was "going for it"
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: scatpacktom] #842460
11/02/10 08:40 PM
11/02/10 08:40 PM
Sask, Can.
Sask, Can.
It is a different block this time and truth be told I got lazy this time and did not dial it in as I did with the last motor. HOWEVER, with that being said it hits all the other gears just fine but with 2'nd it's like there is not even a gate there- nothin'. That to me sounds like Toms theory fits the best.
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: scatpacktom] #842461
11/04/10 02:29 AM
11/04/10 02:29 AM
Sask, Can.
Sask, Can.
Well I took Tom's advise and pulled the reverse switch hex adapter out tonight and it looks like Tom hit it on the nose- the detent ball was MIA. Sooo...thanks Tom!- the next time we meet in Vegas drinks are on me
