Why won't my 4'spd go into 2'nd under high rpm? #842427
10/30/10 11:00 PM
10/30/10 11:00 PM
Sask, Can.
72demon416 Offline OP
Sask, Can.
My trans will shift into 2'nd...ok... under normal driving but when the revs are up it will completely block you out of the gate until the revs drop again. 2 years ago when I grenaded my last engine I was making some passes and missed a powershift into 2'nd on one of my last runs- I'm assuming I damaged something. It use to shift perfect under high rpm...
Or could it be something as simple as pressure on the input shaft from the bell not being dialled in (I'm guessing not likely )
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: 72demon416] #842428
10/30/10 11:12 PM
10/30/10 11:12 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
If pilot hole and face runout are in specs the next thing to check is the clutch air gap. With the pedal pushed to the floor you should be able to get a .040"-".050 feeler gauge between the flywheel and the disc. If you don't have enough air gap you won't get a clean power shift.
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: 446acuda] #842429
10/30/10 11:49 PM
10/30/10 11:49 PM
Sask, Can.
Sask, Can.
At this point a granny shift is not even possible under high rpm. I adjusted the clutch tonight with absolutely no difference...
I'm assuming that if it was a clutch problem there would be a problem with 3'rd as well?
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: 72demon416] #842430
10/30/10 11:58 PM
10/30/10 11:58 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Bad brass syncros in the trans.
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: stumpy] #842431
10/31/10 12:51 AM
10/31/10 12:51 AM
USA
b54406barrel Offline
USA
If it only happens on second gear.
Or maybe a bad 1-2 slider. I use to replace those a lot on Muncies when they wouldn't shift into 2nd under power.
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: b54406barrel] #842432
10/31/10 01:07 AM
10/31/10 01:07 AM
I have encountered the exact same problem with my 833 4 speed in my dart using a centerforce dual friction....its caused by the pressure plate not releasing because of the centrifugal force....i went to a Mcleod soft lock clutch problem solved...amazing clutch...completely adjustable for your application...highly recommended
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: b54406barrel] #842433
10/31/10 01:35 AM
10/31/10 01:35 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: Why won't my 4'spd go into 2'nd under high rpm? #842434
10/31/10 01:41 AM
10/31/10 01:41 AM
Sask, Can.
Sask, Can.
My setup hasn't changed and I've been using the same McLeod clutch setup for 5 years- which shifted into 2'nd just fine prior to my missed shift. I'm leaning towards damaged syncro/slider problems.
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: 72demon416] #842435
10/31/10 05:24 PM
10/31/10 05:24 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
The 833 is notorious for polishing the synchros. I used to keep a spare tranny available with new synchros when I was racing the 4 speed. (Polished synchros will not grab and so you cannot get the slider to engage) Drives around at normal speeds ok, but will not power shift.
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: Cudajon] #842436
10/31/10 07:12 PM
10/31/10 07:12 PM
Texas
70Runnerdude Offline
Texas
Is this the same reason why a friends tranny would pop out of 2nd on deceleration ?
Re: Why won't my 4'spd go into 2'nd under high rpm? #842437
10/31/10 07:51 PM
10/31/10 07:51 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
....using a centerforce dual friction....its caused by the pressure plate not releasing because of the centrifugal force....
not a chance of this being true. Most likely a slider, brass ring or the second gear dog teeth or maybe all three.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: 70Runnerdude] #842438
10/31/10 08:20 PM
10/31/10 08:20 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
70 Runner your friends problem is probably due to linkage adjustment and its not fully engaging 2nd gear. Although bent/missing teeth on the slider or synchro could cause it.
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: 68LAR] #842439
10/31/10 08:22 PM
10/31/10 08:22 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
68LAR I totally agree with you. Centerforce doesn't have that problem.
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: Cudajon] #842440
10/31/10 08:53 PM
10/31/10 08:53 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Worn dog teeth on the speed gear usually cause this.
Rick
Re: Why won't my 4'spd go into 2'nd under high rpm? #842441
10/31/10 09:43 PM
10/31/10 09:43 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My Challenger has a Centerforce. It is with out a doubt the best clutch I have ever used. Many full throttle 12 second passes. I've never even had to adjust it.
Doug
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: Rick_Ehrenberg] #842442
10/31/10 10:01 PM
10/31/10 10:01 PM
Sask, Can.
Sask, Can.
Well it appears the general consensus is that it will have to come out for repairs so it looks like it's time to upgrade to the 18 spline while it's out.
Thanks guys!
Re: Why won't my 4'spd go into 2'nd under high rpm? #842443
10/31/10 10:26 PM
10/31/10 10:26 PM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
The problem often encountered with a diaphragm clutch and high RPM shifts are the clutch pedal not returning due to being unable to overcome the overcenter spring. NEVER have I seen the problem you are describing with the diaphragm or any other clutch.
2 Demons...no, not my kids!
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: 4speeds4me] #842444
11/01/10 09:07 AM
11/01/10 09:07 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
One more thing to consider is to make sure the REVERSE DETENT BALL isn't rolling around in the bottom of the case. They can sometimes pop out and then it is like pulling the shifter into a wall while going for second at high rpm.
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: scatpacktom] #842445
11/01/10 09:42 AM
11/01/10 09:42 AM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
Just tip i used to repair many Japanese car transmissions for polished syncros and a good fix was to use some valve lapping compound and the old syncro/baulk ring to rough up the gear face before putting the new brass balking rings in . That was a T.S.B To hand rough the surface before installing new brass rings. Works great,also 75/140 synthetic lube helps for faster shifts than the thick 80/90 weight. The thinner the fluid the easier for the balk ring to "grab on" anyway good luck man, post up what u find. CJ
1969 Dodge Charger 1969 Dodge Superbee
Re: Why won't my 4'spd go into 2'nd under high rpm? [Re: 72demon416] #842446
11/01/10 10:06 AM
11/01/10 10:06 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I used to have the same problem until I added a solid steel motor mount on the LH side. The factory insulator let the motor torque up too much and bind the shift rods.
Check out the above first before going internal to the trans. If you were getting a "gear clash" into 2nd when power shifting......then I'd jump to the blocking ring/synchro ailment.
