Re: Why won't my 4'spd go into 2'nd under high rpm?
[Re: scatpacktom]
#842449
11/01/10 11:04 PM
11/01/10 11:04 PM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
Well I should have asked the obvious questions before...how will I know if the detent ball has fallen out? (I suppose the reverse lights would not work... ) pull the side cover off and fish for it? or is there a better way? I'm assuming that it gets reinstalled through the side cover opening as well?
[Re: 72demon416]
#842452
11/02/10 11:08 AM
11/02/10 11:08 AM
Posts: 8,940 Holly/MI
Dean_Kuzluzski
Holly/MI
Just undo the rev. rod and shift it into reverse by hand. If the ball fell out, there's no detent and it will be QUITE obvious.
I'd be surprised if that actually has happened. If there's no detent for reverse there'd be other clues, like when you try to shift into reverse.
[Re: Dean_Kuzluzski]
#842453
11/02/10 11:38 AM
11/02/10 11:38 AM
Posts: 3,103 Phila Pa
scatpacktom
Phila Pa
Exactly what would those other clues be Dean? I can't tell you how many people this has happened to, none of them thought it was it either. Don't get me wrong alot of times it is the syncro and it probably is in this case too, but you sure wouldn't pull the trans if you didn't have to. Keep in mind when the ball pops out the spring remains. The ONLY clue the ball has popped out is it won't shift into second at speed.
#842457
11/02/10 01:29 PM
11/02/10 01:29 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Surprised noone mentioned dialing in the bell. If an engine has been rebuilt, or the car is being built to shift fast for any reason, you ned to indicate the bellhousing and make sure it lines up properly with the crank centerline. It's standard practice and the symptoms are most of what everyone is describing. I've not heard of sticky synchros or ever seen them but there's more i haven't seen than I've seen...lol. But I have seen misalignment by as much as .030" that does cause the input to put pressure on the mainshaft and geartrain that makes fast shfting impossible or difficult.
