Why won't my 4'spd go into 2'nd under high rpm?
#842427
10/30/10 11:00 PM
10/30/10 11:00 PM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
My trans will shift into 2'nd...ok... under normal driving but when the revs are up it will completely block you out of the gate until the revs drop again. 2 years ago when I grenaded my last engine I was making some passes and missed a powershift into 2'nd on one of my last runs- I'm assuming I damaged something. It use to shift perfect under high rpm... Or could it be something as simple as pressure on the input shaft from the bell not being dialled in (I'm guessing not likely )
Re: Why won't my 4'spd go into 2'nd under high rpm?
[Re: stumpy]
#842431
10/31/10 12:51 AM
10/31/10 12:51 AM
Posts: 3,054 USA
b54406barrel
USA
Bad brass syncros in the trans.
If it only happens on second gear.
Or maybe a bad 1-2 slider. I use to replace those a lot on Muncies when they wouldn't shift into 2nd under power.
[Re: b54406barrel]
#842432
10/31/10 01:07 AM
10/31/10 01:07 AM
I have encountered the exact same problem with my 833 4 speed in my dart using a centerforce dual friction....its caused by the pressure plate not releasing because of the centrifugal force....i went to a Mcleod soft lock clutch problem solved...amazing clutch...completely adjustable for your application...highly recommended
[Re: Cudajon]
#842440
10/31/10 08:53 PM
10/31/10 08:53 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
70 Runner your friends problem is probably due to linkage adjustment and its not fully engaging 2nd gear. Although bent/missing teeth on the slider or synchro could cause it.
Worn dog teeth on the speed gear usually cause this.
Rick
#842441
10/31/10 09:43 PM
10/31/10 09:43 PM
Posts: 9,839 MI, usa
dvw
MI, usa
My Challenger has a Centerforce. It is with out a doubt the best clutch I have ever used. Many full throttle 12 second passes. I've never even had to adjust it. Doug
[Re: scatpacktom]
#842445
11/01/10 09:42 AM
11/01/10 09:42 AM
Posts: 587 IL . usa
cjs69mope
IL . usa
Just tip i used to repair many Japanese car transmissions for polished syncros and a good fix was to use some valve lapping compound and the old syncro/baulk ring to rough up the gear face before putting the new brass balking rings in . That was a T.S.B To hand rough the surface before installing new brass rings. Works great,also 75/140 synthetic lube helps for faster shifts than the thick 80/90 weight. The thinner the fluid the easier for the balk ring to "grab on" anyway good luck man, post up what u find. CJ
1969 Dodge Charger
1969 Dodge Superbee
[Re: 72demon416]
#842446
11/01/10 10:06 AM
11/01/10 10:06 AM
Posts: 8,940 Holly/MI
Dean_Kuzluzski
Holly/MI
I used to have the same problem until I added a solid steel motor mount on the LH side. The factory insulator let the motor torque up too much and bind the shift rods.
Check out the above first before going internal to the trans. If you were getting a "gear clash" into 2nd when power shifting......then I'd jump to the blocking ring/synchro ailment.
