Re: a/c recharge with r-12
[Re: 69fish]
#84206
07/05/08 12:56 AM
07/05/08 12:56 AM
Posts: 2,001 s. e. pa.
calrobb2000
s. e. pa.
hi you first need to vacuum the system to remove all moisture ,dont skip this step if you want it to work properly ! gage psi should be app 40 low side 240 high side at 80* air temp . low psi is the larger hose size !
[Re: calrobb2000]
#84207
07/05/08 02:13 AM
07/05/08 02:13 AM
I'm going to be brutally blunt, here. I spent about 15 years servicing low, med, and high temp AC and refer units.
You should SERIOUSLY consider hiring someone who knows what they are doing. Refrigerant is nothing to play with. It can seriously injure you, and mistakes in charging--like slugging the compressor with liquid--can turn it into instant junk. Undercharging can be as bad as overcharging, and especially if there is some problem in the system, novices tend to "add more" to see if it will cool.
Once again, a good way to scatter a compressor
240, by the way, is pretty high for a target head pressure with R12. My old Ranger still uses R12, and as i remember, it runs around 180.
[Re: 69fish]
#84209
07/05/08 04:25 PM
07/05/08 04:25 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The rear connection on the compressor is the low side, follow the line entering the rear until you find a charge fitting.
Gauge readings are dependent on outside air temperature.
#84210
07/06/08 01:03 AM
07/06/08 01:03 AM
Dangerous stuff if done wrong. I had an experienced instructor who was missing 3 fingers from a can explosion. Inattention caused him to hook up to the high side and that overpressurized the can. Get help if you dont know what youre doing.
Pete
[Re: 69fish]
#84212
07/06/08 02:38 AM
07/06/08 02:38 AM
RapidRobert
you can do it. Just be cautious,patience & ask for help when needed.
[Re: 69fish]
#84216
07/06/08 03:07 PM
07/06/08 03:07 PM
Posts: 42 S Williamsport
therick
S Williamsport
Some basic questions. I have access to some guages and large container of freon r-12. I'm guessing that you put the freon in on the low pressure side-if this is correct where is the low pressure side fitting and what is the max pressure you should see on the guages when the system is full? Does anyone have a picture of the low vs. high presure fittings? This is for 67 dart with original factory air. Thanks for any and all help.
I'm thinking. If you have to ask these questions. Then you don't have the experience to do this safely.
