Tire Size for a 67 Coronet 325/50-15 #840737
10/28/10 08:51 AM
10/28/10 08:51 AM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
Has anyone successfully installed 325/50/15" M/T DOT tires on a stock 67 Coronet?
RS23L7 4-Speed
Re: Tire Size for a 67 Coronet 325/50-15 [Re: Mopar_Mike] #840738
10/28/10 11:12 AM
10/28/10 11:12 AM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
I have them on my 67 Coronet. Had to mini tub it and moved the springs in 3" using the relocation kit. Running a stock width rearend, drum brakes, 10" rims with 7.5" back spacing. I still have about an inch and 1/16 +/- of room still before I get too close to the frame rails. It works excellent and looks bad a**!!!!!!
Re: Tire Size for a 67 Coronet 325/50-15 [Re: 67dodge67] #840739
10/28/10 11:33 AM
10/28/10 11:33 AM
Danville, NH
Danville, NH
Hmm.. think it can be done without the mini-tub?
RS23L7 4-Speed
Re: Tire Size for a 67 Coronet 325/50-15 [Re: Mopar_Mike] #840740
10/28/10 11:38 AM
10/28/10 11:38 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Not a chance!! 275's will fit with optimum backspacing, but even that's tight and will likely rub a little depending on ride ht.
Re: Tire Size for a 67 Coronet 325/50-15 [Re: 67dodge67] #840741
10/28/10 04:07 PM
10/28/10 04:07 PM
Danville, NH
Danville, NH
Any chance I can see a pick of the mini-tub? (trunk)
Thanks.
RS23L7 4-Speed
Re: Tire Size for a 67 Coronet 325/50-15 [Re: Mopar_Mike] #840742
10/28/10 04:44 PM
10/28/10 04:44 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
MY 67 CHARGER HAS 28 X 14.50 X 15 ON 12" WHEELS WITH 5 1/2" OF BACKSPACING.STOCK WIDTH 8 3/4. I MOVED THE SPRINGS IN 3" PER SIDE AND MINI TUBBED IT. VERY EASY AND WELL WORTH IT. THESE CARS LOOK REALLY GOOD WITH SOME TIRE ON THE BACK.AND NOBODY CAN EVEN TELL WITH THE STOCK INNERS WIDENED.
MOVE THE SPRINGS INTO THE FRAME.
Uploaded with ImageShack.us
WIDEN THE STOCK WHEEL WELLS.
URL=http://img835.imageshack.us/i/998879571ukwsvxl
ITS REALLY NOT TO BAD ONCE YOU DIG INTO IT.i THINK I HAVE ABOUT 5" BETWEEN THE BACK OF THE TIRE AND THE SPRING NOW SO I COULD GO TO A BIGGER TIRE WITH MORE BACKSPACE.
Re: Tire Size for a 67 Coronet 325/50-15 [Re: dragram440] #840743
10/28/10 06:19 PM
10/28/10 06:19 PM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
It looks almost like dragram440's but will get some pics posted for you. I did post some quite some time ago on here... not sure if a search will help you there.
Re: Tire Size for a 67 Coronet 325/50-15 [Re: 67dodge67] #840744
10/28/10 06:44 PM
10/28/10 06:44 PM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
Found some pics... the only thing different from these and what it looks like now is I went back after it was done and finished it off so everything looks straight and the 'seam filler' is gone. Hope these help!
Re: Tire Size for a 67 Coronet 325/50-15 [Re: 67dodge67] #840745
10/28/10 06:45 PM
10/28/10 06:45 PM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
Another...
Re: Tire Size for a 67 Coronet 325/50-15 [Re: 67dodge67] #840746
10/29/10 08:27 AM
10/29/10 08:27 AM
Danville, NH
Danville, NH
Wow, nice job and thanks for the pics. Really for the most part you cannot tell that it was even done. Sounds like its definitely worth it. Thanks guys!
RS23L7 4-Speed
Re: Tire Size for a 67 Coronet 325/50-15 [Re: Mopar_Mike] #840747
10/29/10 11:10 AM
10/29/10 11:10 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
That is exactly how I did mine. 3 1/2" strip in the old wheel well. Cut the floor out flush with the frame rail and move the old wheel well in.
67' charger 499 RB 10.57 at 127
Re: Tire Size for a 67 Coronet 325/50-15 [Re: dragram440] #840748
10/29/10 11:49 AM
10/29/10 11:49 AM
Danville, NH
Danville, NH
Did you guys keep the stock wheel lip? or bend it in?
RS23L7 4-Speed
Re: Tire Size for a 67 Coronet 325/50-15 [Re: dragram440] #840749
10/29/10 11:52 AM
10/29/10 11:52 AM
Danville, NH
Danville, NH
So leave about 3 1/2 inches of the old wheel well (from outside in) and then cut right to the frame rail?
RS23L7 4-Speed
Re: Tire Size for a 67 Coronet 325/50-15 [Re: Mopar_Mike] #840750
10/29/10 12:01 PM
10/29/10 12:01 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I have the stock wheel lip. I used a 3 1/2" wide strip of sheetmetal to widen the inner fenderwell
Re: Tire Size for a 67 Coronet 325/50-15 [Re: Mopar_Mike] #840751
10/29/10 02:12 PM
10/29/10 02:12 PM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
I left it alone. No issues at all! I'll see if I can get some pics of what it looks like now, now that it looks better than what I posted here... Best of luck!
Re: Tire Size for a 67 Coronet 325/50-15 [Re: dragram440] #840752
10/29/10 02:13 PM
10/29/10 02:13 PM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
Re: Tire Size for a 67 Coronet 325/50-15 [Re: 67dodge67] #840753
10/29/10 02:39 PM
10/29/10 02:39 PM
Danville, NH
Danville, NH
Excellent, thank you.. well, since I have u guys attention.. how roll cages? I am looking run about 10.5 when all is said and done. How did u guys do your cages? Pics of course.. Thank you..
RS23L7 4-Speed
Re: Tire Size for a 67 Coronet 325/50-15 [Re: Mopar_Mike] #840754
10/30/10 07:49 PM
10/30/10 07:49 PM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
No cage yet.... still having fun tuning it and getting to the point of needing a cage - best of 11.80 @ 114 and change, 1.61 60'. Not complaining at all for a full steel/interior 67 Coronet. If all goes as planned, Dwayne Porter will be getting my Eddy heads over the winter and having some fun with them... I'm sure after that, I'll be needing a cage. If I recall, S&W has cages/roll bars for 67 Coronet at a very reasonable $$. Might want to look into them when you can... http://www.swracecars.com/index.aspx
Re: Tire Size for a 67 Coronet 325/50-15 [Re: Mopar_Mike] #840755
10/31/10 03:28 PM
10/31/10 03:28 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Here's a pic of my 67 Coronet after being tubbed and relocating the leaf spring perches
Re: Tire Size for a 67 Coronet 325/50-15 [Re: rapom] #840756
10/31/10 03:30 PM
10/31/10 03:30 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Top side
