Re: Barracuda loved cool air.......
[Re: Dragula]
#840710
10/28/10 10:33 AM
10/28/10 10:33 AM
Posts: 214 canada,NB
jb15
canada,NB
Wow....More details please.
The car has a 360ci stroked to 408ci with INDY 360-2 heads,flow 326cfm @.700 int.,238cfm @.750exh.(265cfm with flow pipe).solid roller with gross lifts int.727,exh.697,dur.@.050 int.271.83, exh 291.59. 13:5.1 comp..904 flite with brake,stock 2.45 first ratio, and 6200 conv.dana-60 4.88 gears,33x14x15 slicks,car weighs 2680 with driver,ladder susp. leave on a 4200 chip,shift 1st@7000 2nd 7500, crosses @8000.SV-1 110mm Pro- systems carb.N.A. Jim.
[Re: Thumperdart]
#840715
10/28/10 02:01 PM
10/28/10 02:01 PM
Posts: 2,933 A shed in England
Tig
A shed in England
Awesome BTW was the other car running N2O? Has a big 1/8th mph for the et it ran?
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#840717
10/28/10 02:42 PM
10/28/10 02:42 PM
Tig
A shed in England
Thanks Maybe I should have guessed . In mitigation, over here, they won't let us race cars against bikes.
[Re: jb15]
#840718
10/28/10 02:42 PM
10/28/10 02:42 PM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
You can't run that much horsepower with a stock block, it's going to split in half.
[Re: jb15]
#840719
10/28/10 05:40 PM
10/28/10 05:40 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Awesome numbers. How do you like the SV1 compared to your previous carb?
[Re: jb15]
#840720
10/28/10 06:46 PM
10/28/10 06:46 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
I'm glad to hear it, Jim. I know you've been beating on that ET for the past couple of years. I wonder if that qualifies for The Most Powerful 59º Engine ever? Moroso Power/Speed Calculator = 720 HP
[Re: ProSport]
#840721
10/28/10 07:44 PM
10/28/10 07:44 PM
jb15
canada,NB
Carb is awsem, ran one of Patericks 4150 1000hp bodyed carbs last few years, gained better than a tenth with just the carb change.than came some weight reduction (80lbs)to get the 8.92 run. Jim..
