OOPs - Forgot factory alternator is 50A
#840685
10/28/10 07:47 AM
10/28/10 07:47 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
Don't work very well with 1400 W stereo.....
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
Re: OOPs - Forgot factory alternator is 50A
[Re: 70Coronet500Vert]
#840689
10/28/10 09:17 AM
10/28/10 09:17 AM
Posts: 807 Toronto, Canada
dirtybee
Toronto, Canada
Time for an upgrade.
bought a tuff stuff 100A and new regulator
where did you get it from? i ordered one from summit more than a month ago and it's on backorder. i ordered the black one. also, is a new type of regulator required with a 100 amp alt? thx
#840690
10/28/10 09:26 AM
10/28/10 09:26 AM
Posts: 1,822 Colorado
denfireguy
Colorado
Just out of curiousity what is that stereo fused at? Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
#840691
10/28/10 09:27 AM
10/28/10 09:27 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
What about your wiring ?
[Re: dirtybee]
#840692
10/28/10 10:42 AM
10/28/10 10:42 AM
70Coronet500Vert
St Charles MO
I ordered chrome from summit and it shipped yesterday.
I wanted a new regulator, "just in case"
#840695
10/28/10 11:03 AM
10/28/10 11:03 AM
JohnRR
U.S.S.A.
It is a good point. I have had to replace a couple wires already because they are brittle. I use a high temp wire in 12 gauge for any underhood wiring.
But I think you will need to address the main wire that goes thru the bulkhead and to ammeter and the ammeter , those parts are not rated at 100 amps I am pretty sure .
[Re: JohnRR]
#840696
10/28/10 01:19 PM
10/28/10 01:19 PM
Posts: 18,157 Mass
DAYCLONA
Mass
,...the factory Ampmeter is rated for a peak 70 amps@ 10 mins before it "melts down".....rewire the alternator directly to the starter relay terminal, convert to a volt meter gauge, plenty of aftermarket conversions to retain a somewhat factory appearance,..Redline should be your choice for their conversion gauge
....otherwise running that alternator as is, with no electrical upgrades, you might want to buy an EXTRA fire extinquisher for the "new" radio and alternator, and a set of bolt cutters to clip off the battery wires when its
[Re: DAYCLONA]
#840697
10/28/10 08:04 PM
10/28/10 08:04 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
100A at 13.8V is only 1380 watts.
Almost enough for you amps at max, anything else running will pull from the battery.
Ammeters ONLY measure current to or from the battery, if wired properly. Alternators will ONLY put out enough current to sustain the demand, if working properly.
I would run a heavy gauge wire from the alternator output stud, thru a fusible link or fuse to the amps, I would leave the normal car wiring hooked to the alternator as factory.
I know a bit about electricity and electronics.
[Re: Supercuda]
#840698
10/28/10 10:00 PM
10/28/10 10:00 PM
Posts: 4,748 Florida
BDW
You definitely don't want to get your stero power source from under the dash. Any good installation will connect power directly to battery and use relays to switch on/off.
[Re: Supercuda]
#840699
10/28/10 10:11 PM
10/28/10 10:11 PM
Posts: 30 Texas
GG1charger67
Texas
1400 watts is probable the rated output of the amplifier not the amount it draws.Amplifiers take a small amount of current and amplify it up to create something just this side of distortion.The better quality the amp the less distortion. Some of your better quality amps will be fused at 20 amps and produce 500 watts of power and lesser quality amps fused the same may produce a couple thousand watts of power albeit with plenty of noise (distortion).Subwoofer amps usually gobble up the most power due to the low bass notes.Jason
[Re: GG1charger67]
#840700
10/28/10 11:26 PM
10/28/10 11:26 PM
Posts: 7,647 Houston Texas
PAINT IT BLACK
Got a CHIP on my shoulder
Houston Texas
Run your stereo as a stand alone system. Big fused wire from the battery to a distribution block, and use relays for all your aftermarket stuff. Use in-line fuses as well on stuff like your head unit, eq, and any other gadgets you have. It can get complicated, but it feels good to have peace of mind and know it is wired up right.
These metal plates are bolted to magnets and the magnets hold it all to the underside of my Cuda's dash. I have a 4 channel and a 2 channel amp, a head unit, eq, electric cutouts, electric vacuum pump (brakes), roll control, my ammmeter, volt meter, and tach, as well as all the lighting for my gauges hooked up through this auxilary system.
[Re: BDW]
#840702
10/29/10 09:07 AM
10/29/10 09:07 AM
70Coronet500Vert
St Charles MO
Gents, I have done this before. I have a 2 gauge wire to the trunk from the battery. There is a 100A CB about 5 inches from the battery.
I have routed the amp turn on lead to control the amps. I need to check the dash, but I think this has already been converted to read voltage, not amps, so this may be much ado about nothing in my case, but very good info for those who do not have the conversion.
I went with a 100A alternator because I did not want to mess with all new brackets for a 140A alternator. Also, while max power is indeed 1380 watts w/o negatively affecting the battery, normal listening volumes are significantly lower so 100A should still let me charge the battery, which the 50A was not.
The 4 channel Audiobahn amp has 2 - 30 amp fuses and the 2 channel Audiobahn amp has a 30 amp fuse. I should be all good at 100A.
This is a great thread though. I had not thought about the ammeter on the dash til John mentioned it.
[Re: ahy]
#840704
10/29/10 10:16 PM
10/29/10 10:16 PM
Supercuda
About to go away
About to go away
up yours
Wiring an amp, or any load, to the battery is a great way to ensure that all the current draw will pass thru the ammeter all the time.
There is a reason the factory wired all normal loads to not pass thru the ammeter,. I suggest you rethink your plan and wire it to the alternator output stud.
One other point, input wattage will always exceed output wattage. It's a fact of efficiency, if your amp has a 20A fuse protecting it then it's maximum input wattage is 276W (13.8V x 20A). There is no way the output wattage can exceed that. In fact it's probably under 250W.
To be honest, a 1400W amp will probably draws in excess of 140A at max output.
