POR 15 on an engine block #840618
10/27/10 11:34 PM
10/27/10 11:34 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Haven't been on Moparts for months. Little burned out on cars for a while.
Anyway, I have a complete engine with surface rust on the block. I was going to wire brush it and then paint it with a rattle can. Was thinking of putting POR 15 on the surface rust and then painting over it. Will this work?
Re: POR 15 on an engine block [Re: VITC_GTX] #840619
10/27/10 11:53 PM
10/27/10 11:53 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
Hi I have painted two engines with por -15 products .
IF you you use their por 15 engine enamel it will come out great .
I caution using spray paint over the por-15 because it may peal off because por-15 has only a small window to top coat the por needs to be tacky to almost dry . This means it has to be top coated in 4-5 hours to get the best adhesion . you can look all this stuff up on the por 15 web site technical info . hope this helps . p.s. get the clear coat from por if you use their engine enamel or it will discolor if you ever spill anti freeze or fuel on the intake . cj
1969 Dodge Charger 1969 Dodge Superbee
Re: POR 15 on an engine block [Re: VITC_GTX] #840620
10/27/10 11:56 PM
10/27/10 11:56 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I have no idea if the POR stuff can handle the engine heat. If it can then it's probably no big deal.
Personally I'd just wire brush it until it's clean and then apply the color.
Re: POR 15 on an engine block [Re: Neil] #840621
10/28/10 12:02 AM
10/28/10 12:02 AM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
heat is no problem
Re: POR 15 on an engine block [Re: cjs69mope] #840622
10/28/10 03:32 PM
10/28/10 03:32 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I use Magnet Paints chassis saver and with scuffing paint sticks great even after it dries or you can top coat it within an hour, but never tried it. My experiences with por-15 have been poor at best.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: POR 15 on an engine block [Re: VITC_GTX] #840623
10/28/10 04:25 PM
10/28/10 04:25 PM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
It wasnt a block, but I coated a set of stock steel valve covers with regular POR-15, and spray bombed Hemi Orange over that. It has lasted 10+ years.
Hope this helps!
Paul
'69 Super Bee 383 EFI Turbo
Re: POR 15 on an engine block [Re: Black_Bee] #840624
10/28/10 10:02 PM
10/28/10 10:02 PM
Throw the POR-15 in the trash and use a good epoxy primer after you gett all the rust off.
I thought everyone knew how Sh#&^$ POR-15 was by now....
Re: POR 15 on an engine block #840625
10/28/10 10:11 PM
10/28/10 10:11 PM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
just make sure you prep everything properly like the instructions say and you'll be fine. its very time consuming but I've had good results. I used their engine kit on my 360 in the beginning of summer and it seems to be holding up well so far.
Re: POR 15 on an engine block [Re: chache876] #840626
10/29/10 12:07 AM
10/29/10 12:07 AM
SW MO
closer9 Offline
closer9  Offline
SW MO
I did a block and heads about 10 years ago. Just left it the POR-15 black. It held up great with the heat, and since it wasn't exposed to sunlight, I didn't have to worry about a topcoat... I've used POR-15 on several things, and never had any problems with it...
I used their complete engine kit per the instructions when I built my recent 318...
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
