Re: What springs do you run on your MP distributor?
[Re: Pacnorthcuda]
#84029
07/04/08 10:06 PM
07/04/08 10:06 PM
RapidRobert
from an old mopar action tech mag. (1) single stock light 2200. (2)stock lights 2400. (2)MP springs 1100rpm
[Re: Pacnorthcuda]
#84030
07/05/08 12:26 AM
07/05/08 12:26 AM
Anybody run only ONE spring?
yup. works well. all in just off idle.
[Re: 68jim]
#84033
07/05/08 10:37 AM
07/05/08 10:37 AM
RapidRobert
yes if I can figure out how to fine tune my new(& 1st digital) camera. It's in a "Mopar Tech special" magazine vol 4, #1 1997, issue #6
[Re: Pacnorthcuda]
#84034
07/06/08 01:06 PM
07/06/08 01:06 PM
Posts: 1,396 Mass
dgc333
Mass
I just installed a new MP (RB) distributor. I was expecting all the mechanical advance in by no more than 2500 but it more like 3000-3500. The springs are one light, one heavy (or at least heavier). Are two lights likely to get me all in by 2000?
If it's a new MP distributor it will have the Mallory advance mechanism in it. You can pick up a Mallory distributor tuning kit #29014 from Summit or Jegs that will come with an assortment of springs and spacers for setting the advance stops. The kit also has charts that show the advance curves with the different springs.
Don't know if the previously posted chart would apply to one of the Mallory made distributors.
[Re: dgc333]
#84035
07/06/08 02:00 PM
07/06/08 02:00 PM
RapidRobert
the(3)different crane springs used in the article were in a kit thats no longer available.It had IIRC (1)orange spring (1)yellow spring & (1)plain colored light spring similar to the factory light spring.
