What springs do you run on your MP distributor? #84028
07/04/08 08:10 PM
07/04/08 08:10 PM
Kirkland, Washington
Pacnorthcuda Offline OP
I just installed a new MP (RB) distributor. I was expecting all the mechanical advance in by no more than 2500 but it more like 3000-3500. The springs are one light, one heavy (or at least heavier).
Are two lights likely to get me all in by 2000?
Anybody run only ONE spring?
Re: What springs do you run on your MP distributor? [Re: Pacnorthcuda] #84029
07/04/08 10:06 PM
07/04/08 10:06 PM
from an old mopar action tech mag. (1) single stock light 2200. (2)stock lights 2400. (2)MP springs 1100rpm
Re: What springs do you run on your MP distributor? [Re: Pacnorthcuda] #84030
07/05/08 12:26 AM
07/05/08 12:26 AM
yup. works well. all in just off idle.
Re: What springs do you run on your MP distributor? #84031
07/05/08 09:41 AM
07/05/08 09:41 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
RapidRobert,
The chart is a bit hard to see. Any chance of a better scan/picture? What issue did that article appear?
Thanks,
68Jim
Re: What springs do you run on your MP distributor? [Re: 68jim] #84032
07/05/08 10:29 AM
07/05/08 10:29 AM
New York
rarefish Offline
rarefish  Offline
New York
Mp must have change the advance curve because the ones that I have checked were fully advanced at around 1800-2000 rpm. That is a little too early for a street driven car.
Re: What springs do you run on your MP distributor? [Re: 68jim] #84033
07/05/08 10:37 AM
07/05/08 10:37 AM
yes if I can figure out how to fine tune my new(& 1st digital) camera. It's in a "Mopar Tech special" magazine vol 4, #1 1997, issue #6
Re: What springs do you run on your MP distributor? [Re: Pacnorthcuda] #84034
07/06/08 01:06 PM
07/06/08 01:06 PM
Mass
dgc333 Offline
dgc333  Offline
Mass
If it's a new MP distributor it will have the Mallory advance mechanism in it. You can pick up a Mallory distributor tuning kit #29014 from Summit or Jegs that will come with an assortment of springs and spacers for setting the advance stops. The kit also has charts that show the advance curves with the different springs.
Don't know if the previously posted chart would apply to one of the Mallory made distributors.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: What springs do you run on your MP distributor? [Re: dgc333] #84035
07/06/08 02:00 PM
07/06/08 02:00 PM
the(3)different crane springs used in the article were in a kit thats no longer available.It had IIRC (1)orange spring (1)yellow spring & (1)plain colored light spring similar to the factory light spring.
