please,HELP, removing rear 1/4 glass,70 R.R.
#84013
07/04/08 05:08 PM
07/04/08 05:08 PM
Posts: 3,426 weymouth,mass.
meepmeep70
weymouth,mass.
i have the rear 1/4 glass assembly that i want to clean so i can install tonight after work,these are the rear glass that pop out not roll down,is there some trick to remove the glass? i don't see any type of fasteners. thank you and i await your help (1970 road runner)
Re: please,HELP, removing rear 1/4 glass,70 R.R.
[Re: 68KillerBee]
#84018
07/04/08 07:08 PM
07/04/08 07:08 PM
meepmeep70
weymouth,mass.
thanks for trying to help killer,ya that seal? one of my window seals to the 1/4 had the 3M type body sealer putty stuffed under the rubber,so it looked like it fit tight,the other nothing. it is amazing the things you find and that these cars lasted as long as they did with that kind of craftsmanship. if i get an answer i'll let you know.
