Re: Easy Fuel Pump Question for Gearheads!
[Re: BAM]
#838949
10/26/10 10:27 PM
10/26/10 10:27 PM
RapidRobert
I'd pull the pipe plug (& they come loose better w jerking hard on the wrench rather than a steady pull on ones that are tight) & take out the rod & check for scalloped wear (std length is 3&1/4") & if you got it out I'm assuming it is not mushroomed badly. I'd want to know everythings' condition & go from there
