Big Cam x Low Compression Ratio #83875
07/04/08 08:14 AM
07/04/08 08:14 AM
Sao Paulo, Brazil
dart_73_br Offline OP
Sao Paulo, Brazil
Hi guys,
I had a problem during the building of my 318 project so I had to finish the engine build up with the cast pistons and rings.
The problem is that my engine is mounted with a big cam and low compression ratio.
What should happen with this setup ?
Cast heads with 2.02/1.6 valves
EFI Megasquirted
Single Plane Torker 2 modified for EFI
7.5 CR
240/246 @.050 .507 .510 cam lobe 110º overlap 70º
So... how it´s going to work guys ?
I´d like to achieve at least 9.5~10 CR but it will be done just in the next rebuild.
Regards,
Fernando
1973 Brasilian Dart
E100, boosted 390"
Re: Big Cam x Low Compression Ratio [Re: dart_73_br] #83876
07/04/08 09:14 AM
07/04/08 09:14 AM
Andrews,In. U.S.of A.
67_Satellite Offline
It's going to be "soggy" on the bottom end no matter what you do. The best you can do is advance the cam,and get all of your ignition timing in early. A loose convertor and low rear gears would help too.Look at the bright side,when you finally get the compression up to match the cam and intake,it will feel like you added a blower.
Re: Big Cam x Low Compression Ratio [Re: dart_73_br] #83877
07/04/08 09:18 AM
07/04/08 09:18 AM
IN
ahy Offline
ahy  Offline
IN
Big cam + low CR + 318" + single plane intake = low & mid range very weak. It just won't have much cylinder pressure or torque. It may not wake up until 5000 or 6000 RPM and won't like to idle. Mileage won't be very good either.
I'm no cam expert but I'd suggest with your short block a cam that is 210 or max 220 @ .050 would work much better. So would a dual plane intake but you've already got the EFI single plane.
If time and budget don't permit increasing CR now suggest you at least change the cam so you can enjoy driving it.
My
Re: Big Cam x Low Compression Ratio [Re: ahy] #83878
07/04/08 09:26 AM
07/04/08 09:26 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
My
Re: Big Cam x Low Compression Ratio [Re: dart_73_br] #83879
07/04/08 09:29 AM
07/04/08 09:29 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
2 options, 1 - pull the cam and get a good grind for your combo. 2 - boost it
Re: Big Cam x Low Compression Ratio [Re: dart_73_br] #83880
07/04/08 09:35 AM
07/04/08 09:35 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Those big valve heads are more than likely going to hurt you more than help you.
Re: Big Cam x Low Compression Ratio [Re: MoparforLife] #83881
07/04/08 10:14 AM
07/04/08 10:14 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
What you people are forgetting is that port EFI lets you get away with a lot of stuff that you can't get away with on a carb. IE single plane intakes don't kill bottom end, because there's signal to the carb to worry about anyway. Same with hi-flow heads, but to a lesser extent.
But either way, that is a gigantic cam for a 318. Heck with that huge duration and 70* overlap, I wouldn't run that cam in a 440 with any less than 10:1 CR, and for that to run well in a small block, I would have to build a sky high CR. That's just way way too much cam my friend. Take it out and sell it. If you're low on cash, one of the cheapie summit cam/lifter kits will make more power throughout the entire RPM range than than monster you have in their now.
Re: Big Cam x Low Compression Ratio [Re: DaytonaTurbo] #83882
07/04/08 01:19 PM
07/04/08 01:19 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
With the EFI my engine idles @ 700 rpm
with this wrong configuration...
You can see it idling here...
http://www.youtube.com/watch?v=JYn04t_URjU
http://www.youtube.com/watch?v=FJ_lb9kaZBw
Looks like I have a lot of homework to do..
I already have a set of JE forged pistons. These pistons look great and are lightweight. Problem is that they are 3.97" and I´m a little afraid of boring the block this much. They will give me 10.5:1 CR (aproximatly).
Should I sell these pistons and go buying another ones ? I have the option of buying some Keith Black domes KB-399 that should give more than 11:1 CR. How much power these KB can handle ?
I want to use some juice in the future. (100~150hp).
Thanks for your attention guys,
1973 Brasilian Dart
E100, boosted 390"
Re: Big Cam x Low Compression Ratio [Re: Mr.Yuck] #83883
07/04/08 02:42 PM
07/04/08 02:42 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
With your compression and fuel injection, BOOST IT!
Re: Big Cam x Low Compression Ratio [Re: dart_73_br] #83884
07/04/08 03:57 PM
07/04/08 03:57 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Advance your timing to 50 total and see how it runs. I have small valve 360 heads on my teen and a 292/501 cam in it. It ran like a raped ape with a 4 speed and 3:91 gears. My idle is at 900 to 1000 rpm now. I have it in a dakota with a 727 and a 3500 stall. With my poor gearing (3:55)I have now it is kinda doggy. I have not got WOT figured out yet and I should have my 4:10 in next week. That ought to wake it up quite a bet.
Re: Big Cam x Low Compression Ratio [Re: 68Bullit] #83885
07/04/08 07:04 PM
07/04/08 07:04 PM
Interesting concept here.
http://www.ststurbo.com/
Re: Big Cam x Low Compression Ratio #83886
07/04/08 08:48 PM
07/04/08 08:48 PM
Manitoba, Canada
Manitoba, Canada
Cool idea in theory, but all that extra piping makes me want to !
Re: Big Cam x Low Compression Ratio [Re: DaytonaTurbo] #83887
07/04/08 09:44 PM
07/04/08 09:44 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
I just drove the car... for the frst time after finishing exhaust, installed O2 sensor...
and surprise... it's a big
Looks like the Adams Family car...
I'll have to rebuild the engine... change pistons... how much CR should I look ? For street/strip ?
10 ? 10.5 ?
I also want to use some juice after that... maybe 100~150hps..
What kind of pistons do you recomend me ?
Hypereutetic handle nitrous ?
BR guys and thanks,,,
1973 Brasilian Dart
E100, boosted 390"
Re: Big Cam x Low Compression Ratio [Re: dart_73_br] #83888
07/04/08 11:24 PM
07/04/08 11:24 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I would shoot for at least 10 to one. That should wake it up quite a bit and run on 93 octane just fine. If you went to 11 to one you might be able to get away with 93 with a bunch of tuneing, low temp t-stat ect... Don't you have easy access to ethenol down there? If so you can run monstrous compression on it, with that cam you could get away with 14 to one easily. Nitrous and ethanol go together great
Re: Big Cam x Low Compression Ratio [Re: HotRodDave] #83889
07/05/08 12:18 AM
07/05/08 12:18 AM
Manitoba, Canada
Manitoba, Canada
Shoot for 10.5:1 and quench - if running open chamber heads, use quench dome pistons. Scrap that cam either way. It WAY big. That's about as big of a cam as you can go on a streetable 10-11:1 440, nevermind a little 318.
If you want to run nitrous or boost, go with forged pistons. Hypers will take it, but if you run into detonation with nitrous, hyper pistons will shatter, and stock cast pistons will melt down. Forged will survive a lot better.
Re: Big Cam x Low Compression Ratio [Re: DaytonaTurbo] #83890
07/05/08 09:04 AM
07/05/08 09:04 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Add up all you costs Pistons, machine work, rods, and so on. You can probably get a used S/C off a 5.0L for around $1500.
Re: Big Cam x Low Compression Ratio [Re: Mr.Yuck] #83891
07/06/08 09:55 PM
07/06/08 09:55 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
I'm adding a pcture of the dataloging I've made.
Note that when idling... the engine stays accelerating ... it comes up and down... look at the MAP curve... the pressure inside the intake manifold flutuates... it's the blue curve...
This is because the low cylinder pressure ?
What do you think guys?
BR,
Fernando
1973 Brasilian Dart
E100, boosted 390"
Re: Big Cam x Low Compression Ratio [Re: dart_73_br] #83892
07/06/08 10:02 PM
07/06/08 10:02 PM
IN
ahy Offline
ahy  Offline
IN
Wide fluctuations in MAP are a characteristic of a long duration/high overlap cam. The settings in the engine control computer can exagerate or reduce this effect but its mostly the cam characteristic combined with the effect of engine displacement.
Re: Big Cam x Low Compression Ratio [Re: ahy] #83893
07/06/08 10:31 PM
07/06/08 10:31 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
Found the right word guys...
it surges...
1973 Brasilian Dart
E100, boosted 390"
Re: Big Cam x Low Compression Ratio [Re: dart_73_br] #83894
07/07/08 11:44 AM
07/07/08 11:44 AM
Manitoba, Canada
Manitoba, Canada
Map readings all over the place are normal with a huge cam like that + small ci + low compression. In all honesty, you're not going to be able to get it to run right with that cam no matter what you do. Go stick a cam in that thing with specs no bigger than a stock 340 cam, then you will have something that is actually driveable.
