Re: Mercedes fan upgrade
[Re: Andrewh]
#838310
12/23/10 07:02 PM
12/23/10 07:02 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Andy, he's going to do some on-vehicle testing before he sends it to us.
[Re: feets]
#838313
12/29/10 10:27 PM
12/29/10 10:27 PM
Posts: 3,902 Oregon
hooziewhatsit
Success Finally got the alternator installed, and got a break in the snow today, so I was able to let the fan run for an hour. It got cold and dark, so I didn't go any longer than that It otherwise seemed to work just fine; no smoke from its controller, or turning off by itself. I think at this point I just need to finish up the circuit board and start moving forward with building them.
[Re: hooziewhatsit]
#838314
12/29/10 10:45 PM
12/29/10 10:45 PM
gtx69
super gas
super gas
[Re: DaveRS23]
#838316
01/02/11 11:14 PM
01/02/11 11:14 PM
Posts: 3,902 Oregon
hooziewhatsit
Ok, I have some more questions. Once the temperature reaches the set temp, the fan turns on. How many degrees do you want it to go down before turning the fan off? 5? 10? 15? I have room for another dip switch to select between a big drop and lower drop in temperature. Well, I guess I only had one question
[Re: Andrewh]
#838318
01/03/11 12:52 AM
01/03/11 12:52 AM
Posts: 3,902 Oregon
hooziewhatsit
The turn on temperature will be adjustable from 160 to 240. (I don't think I need to go any lower, or higher?).
Then once the fan turns on it'll run until the temp drops 10 degrees?
With the switch it can drop 5 or 10. 7 or 15. Or any other two temps that make sense.
[Re: Andrewh]
#838320
01/03/11 01:16 PM
01/03/11 01:16 PM
gtx69
super gas
super gas
[Re: gtx69]
#838321
01/03/11 04:54 PM
01/03/11 04:54 PM
feets
Senior Management
Senior Management
Irving, TX
10 degrees should be plenty.
Did you get the alternator installed and the truck ready to test?
[Re: Andrewh]
#838325
01/07/11 07:23 PM
01/07/11 07:23 PM
Posts: 3,902 Oregon
hooziewhatsit
Starting on the left, there is Power ground Trigger to fan Status output AC input Sensor input sensor ground
I couldn't find an ideal box, so I found one that will completely enclose the board. You (or me) can drill a hole in the box to run the wires through. Then you use the screw terminals to attach them to the board. I'm going to align the hole on mine to be pointing down (with be either side or the end of the box). The board will also be sprayed with a protective coating to help prevent any small splashes/condensation from doing anything bad.
The plastic black box is ~2"x4"x0.88" and has mounting tabs. The board is ~1.5" square.
The DIP switches are pretty tiny, and so is the knob to set the turn on temperature. Basically you'll set them with the top of the box off, run it up to temp to make sure it all works, then you can put the top on and forget about it. When I ship them out I'll have the temp set to ~210*.
[Re: Andrewh]
#838327
01/07/11 07:59 PM
01/07/11 07:59 PM
Posts: 3,902 Oregon
hooziewhatsit
The box will look approximately like this one (it's a stock photo, so the dimensions may be off). link. The screw terminal will look like this one link. Personally, I'd prefer to run the wires into the box and use the screw terminals, than have a bundle of butt-connectors just outside I thought about adding a connector, but that would likely add another $10+ to the price The good ones are not cheap. And then I need to have the boxes cut to fit the plug, make sure it's sealed, etc.
[Re: Andrewh]
#838329
01/07/11 09:24 PM
01/07/11 09:24 PM
Posts: 3,902 Oregon
hooziewhatsit
A similar style looks like this. link, but to change anything, you'd have to unmount the entire box, then take the top off. I'm not seeing any plastic boxes, with a mounting flange, that are sealed with a gasket. I have some similar plastic boxes from other projects that close tight enough that unless it's submerged in water, they pretty much don't leak at all. A casual splash would be fine. It also wouldn't be too hard to run a thin strip of RTV around the edge before putting the lid on. There are plenty of aluminum boxes with seals and flanges, but the cost goes from ~$4, to ~$12-15+ each. And if the customer drills the wire hole, metal flakes going everywhere could be a concern. The board will sit on four 1/4" tall plastic standoffs that have a sticky base.
