Re: 1974 Low Comp 440 what can you expect on a budget.....
[Re: 1964Polara]
#838144
10/25/10 09:21 AM
10/25/10 09:21 AM
Posts: 1,894 Mira Loma, CA
69B3GT
Mira Loma, CA
Lets say, you have a 1974 440 Low Comp out of a 1974 Fullsize available and just want to spent a few parts:
Edelbrock Perfomer RPM Intake +/-750cfm Carb Holley 4 barrel wealthy Hydraulic Camshaft (Lunati Voodo or Comp Cams X or Hughes) Headers
How much HP can you expect from that poor 8,5:1 CR Engine?
Ill be watching this, the 440 i have is a 74 also. Good luck
[Re: Mr.Yuck]
#838145
10/25/10 09:41 AM
10/25/10 09:41 AM
Posts: 161 Huber Heights Ohio
greenpigs
Huber Heights Ohio
The Voodo 302 should be good and unless you plan on running a 4.10 or steeper gear stick with a low rise dual plane.
69 Charger RT
[Re: 1964Polara]
#838150
10/25/10 02:29 PM
10/25/10 02:29 PM
DaytonaTurbo
Manitoba, Canada
See here for some inspiration: https://board.moparts.org/ubbthreads/show...&PHPSESSID=My old combo. I was planning to rebuild my 440 but couldn't make it happen financially so instead of letting all my parts sit I threw them together to have some fun with: Stock 76 440, hone'n're-ring with new cast pistons 440 source heads Lunati Voodoo 60303 cam Summit el-cheapo headers Stock intake w/ thermoquad Recurved distributor Stock converter and a 3.55 rear gear Never had it to the track but tooled around with it a lot around town. Made a decent amount of power and enough to put on a good show when I nailed the GO pedal. Popped off the header cutouts and guys would come up to my car drooling, then grinning ear to ear after after I filled the area with smoke from doing a few hard launches and some doughnuts. It ran decent for what it was, however I figured the stock intake was holding me back and a bit more gear and converter would have made all the difference. A recurved distributor is a MUST. That combe needed a lot (18-20*)of initial timing to run properly. Throttle response during normal driving was good, almost as good as it was when I had the stock cam in there. I was pretty satisfied with how it ran all things considered.
[Re: 1964Polara]
#838151
10/25/10 05:50 PM
10/25/10 05:50 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Mr.Yuck]
#838152
10/25/10 05:55 PM
10/25/10 05:55 PM
Von
NE Oklahoma
w/ a cheaper dual plane like a used Holley SD or Eddy CH4B.
Holley SD is a single plane.
[Re: 1964Polara]
#838153
10/25/10 06:55 PM
10/25/10 06:55 PM
Posts: 3,897 St. Louis, MO
Blues_Cuda
St. Louis, MO
One of my responses from this post... https://board.moparts.org/ubbthreads/show...rt=all&vc=1Back in the early '90s we threw a '74 cast crank 440 into our 3775lb '64 Savoy to go have some fun. It was literally a $200 junkyard motor and trans. We left the stock pistons, rods, crank, bearings...everything. We put in a used .509 cam and lifters, Team G single plane intake, 750 Holley, TCI 10" converter, and 4.56 gears. The car ran 12.80's like clockwork. We then freshened the 452 heads and put on a Max Wedge intake w/ two 600 Carters. It ended up running 12.40's @ 108 mph. The engine would just not give up...it still ran when we pulled it in the late '90s for the 'good' engine. The short block is actually still under the bench in my parents garage. We all joked that it did not have enough power to blow itself up. Oh yeah...the compression worked out to be 7.8:1 in the good cylinders.
[Re: Blues_Cuda]
#838155
10/26/10 06:31 AM
10/26/10 06:31 AM
69B3GT
Mira Loma, CA
No compression and 12.80s would make me happy, id be able to beat almost all my friends cars, and it would run on dog water
[Re: 69B3GT]
#838156
10/26/10 10:18 AM
10/26/10 10:18 AM
Von
NE Oklahoma
Thats what I was looking for Blues... A member on here (forphorty) has a low compression 440 (high mileage short block also) with a 292 Comp cam, Torker intake, stock valved 906s (chambers were polished, so compression is a hair lower than stock), headers, 750 DP, 3500 stall, and ding ding.... 3.23 gears. 3500-3600 lbs. Car has ran in the 12.30s.
[Re: Von]
#838158
10/26/10 11:03 AM
10/26/10 11:03 AM
Posts: 6,568 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
If this is truly a budget deal ie you're not rebuilding this engine, I would call Dwayne Porter http://supercarraces.com/Porterracing.html for a custom cam for your combo. I would get the distributor re-curved and run a good coil with an MSD 6AL or go with one of Firecore50's ready to run setups and the best headers I could afford sized for the combo. I would save my $$$ and keep the stock intake and Thermoquad carb. Unless you get the heads ported or go with Edelbrocks or something it will be out of any serious steam by 5500 anyway and the stock intake much as you might hear to the contrary is as good as anything out there up to that point. It should do 1HP/cubic inch give or take easy. Kevin
[Re: 1964Polara]
#838159
10/26/10 12:30 PM
10/26/10 12:30 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
I used a 78 cop motor with a 509 MP cam and got 12.88@108 with a stock TQ intake and a 750 Holley Spreadbore double pumper. On thing that you may have to do is trim the tops of the valve guides down I had retainer to guide issues with a 509 and 452 heads. I was only running a 3.23 gear and the car weighed 3700# Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#838160
11/24/10 08:07 AM
11/24/10 08:07 AM
Posts: 296 Germany
1964Polara
Germany
I used a 78 cop motor with a 509 MP cam and got [Email]12.88@108[/Email] with a stock TQ intake and a 750 Holley Spreadbore double pumper. On thing that you may have to do is trim the tops of the valve guides down I had retainer to guide issues with a 509 and 452 heads. I was only running a 3.23 gear and the car weighed 3700# Gus
Is the triming of the valve guides what Comp Cams means if they write: "Requires machining on cylinder heads" ???
