440 RV engine
#83784
07/03/08 10:54 PM
07/03/08 10:54 PM
I am a rookie Mopar Guy. Bought a 72 Satellite soon to be Roadrunner clone. A friend has a 440 RV motor. Currently has 318. What is the difference between 440 Car motor vs. 440 RV motor. Thanks!!
Re: 440 RV engine
[Re: DaytonaTurbo]
#83786
07/04/08 12:06 AM
07/04/08 12:06 AM
Posts: 2,042 Leucadia, Ca.
vdriver
Leucadia, Ca.
I've pulled many a 440 out of motorhomes. The general rule of thumb is from '72 thru '75 they used forged cranks & six-pack rods, & lots of 'em came with a windage tray. Starting in '76 they switched to cast cranks. There will probably be some that say they've seen steel cranks in the later motors; I have no reason to doubt that. My own '76 Jamboree has a cast crank 440. One thing I like about the MH engines is they rarely have a lot of miles racked up on 'em; most of the ones I pull out of the locals yards have less than 60k. Usually the bodies give out long before the drivetrain. The result is a nice block with minimal ring ridge. I have 3 spare bare blocks with less than 60k on them with hardly any ridge at all. Up til '72 most big block Mopar motorhomes came with 413s.
Re: 440 RV engine
#83787
07/04/08 08:24 AM
07/04/08 08:24 AM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
Hey Lou, will you get the tranny with the engine? I was wondering if the 727s out of the motor homes are special in any way, i.e. heavier duty???. Has anyone else had any experience with this?
Russ:)
BigBlock 74 Swinger
Re: 440 RV engine
[Re: bb74swngr]
#83789
07/04/08 09:23 PM
07/04/08 09:23 PM
He did say the tranny is a short tail.
Re: 440 RV engine
[Re: dogdays]
#83792
07/08/08 01:24 PM
07/08/08 01:24 PM
Posts: 3,329 Melbourne, FL
dwbiggs
super gas
super gas
Melbourne, FL
I have a '73 440 and it has a cast crank and came with 213 heads. It does have the different water pump housing with the outlet on the passenger side. Pic showing pump housing.
Re: 440 RV engine
[Re: dogdays]
#83794
07/08/08 07:22 PM
07/08/08 07:22 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
I think the bottom line is, that it all depends on the rv.
I've seen 440's in mh's that were forged cranks, up into 79(winni class a chassis) Class C chassis(van front), most got cast crank passenger motors with the only real difference being in ex manifolds, and oil pan.
The water pump side to side difference was also seen on the cars in the later years of production.
Re: 440 RV engine
[Re: dogdays]
#83795
07/09/08 08:33 AM
07/09/08 08:33 AM
dwbiggs
super gas
super gas
Melbourne, FL
The 213 heads sometimes known as "motorhome heads" were also found in Chrysler passenger cars like my 1973 400 2-barrel and are NOT the weird heads.
What are we calling the "weird" head? 213's had the cooling passages around the plugs.
