'69 Saginaw P/S pump/pulley experts #837835
10/24/10 08:23 PM
10/24/10 08:23 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
I am in process of restoring the saginaw power steering pump for my 69 roadrunner. It is an A/C car. The pulley that was on the pump that came off the car (shown on left) looks to be a '71 pulley (1281 is number on front). I also have a '69 and '70 pulley of the same diameter but their offsets are different. I wanted to use the '69 pulley but its offset is so different, I don't believe it will work.
Also have two Saginaw pumps ... the return on each is different.
Can anyone advise as to the correct pulley/offset and pump return for my application?
Thanks!
Re: '69 Saginaw P/S pump/pulley experts [Re: 70mopes] #837836
10/24/10 08:24 PM
10/24/10 08:24 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
Another
Re: '69 Saginaw P/S pump/pulley experts [Re: 70mopes] #837837
10/24/10 08:24 PM
10/24/10 08:24 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
last
Re: '69 Saginaw P/S pump/pulley experts [Re: 70mopes] #837838
10/24/10 08:28 PM
10/24/10 08:28 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
Also, the 69 pulley does not have a keyway. Both of my pumps have provision for a key.
Re: '69 Saginaw P/S pump/pulley experts [Re: 70mopes] #837839
10/24/10 08:32 PM
10/24/10 08:32 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
pumps
Re: '69 Saginaw P/S pump/pulley experts [Re: 70mopes] #837840
10/24/10 11:37 PM
10/24/10 11:37 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
That pulley looks like it is for the Federal pump that uses no key or bolt to hold it on.
Re: '69 Saginaw P/S pump/pulley experts [Re: Steve340] #837841
10/25/10 12:56 AM
10/25/10 12:56 AM
Fremont, CA.
Topcat Offline
Topcat  Offline
Fremont, CA.
Nope
Re: '69 Saginaw P/S pump/pulley experts [Re: Topcat] #837842
10/25/10 05:33 PM
10/25/10 05:33 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
You don't want to use the non-key way pulley on the keyed shaft. Are you saying the press on pulley came off your original pump with the keyed shaft? That doesn't seem right unless someone changed the pulley sometime.
