Valve Adjustment #83781
07/03/08 11:54 PM
07/03/08 11:54 PM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
I have a 440 with a fairly mild Utradyne cam, hydralic lifters, and adjsutable rockers.
I would appreciate any advise on adjusting the valves.
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: Valve Adjustment [Re: Hrtbkr] #83782
07/05/08 09:08 PM
07/05/08 09:08 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
BTT
Re: Valve Adjustment [Re: TJP] #83783
07/05/08 09:33 PM
07/05/08 09:33 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Make sure that the lifter for the rocker you are adjusting is on the base circle of the loosen rocker till you have free play between the rocker, pushrod, and valve tip. tighten adjuster till this free play (gap) is gone plus about 1/2 turn.
