arc switch panel mounting #837309
10/24/10 07:47 AM
10/24/10 07:47 AM
W.Va
fowl play Offline OP
W.Va
bought a nice previous owned switch panel for my race dart. this winter's project. it can be mounted on the cage or on a mount somewhere else. i can't decide what to do with it. old switches are between seats. some pictures of your panels would be a great help. thanks
Re: arc switch panel mounting [Re: fowl play] #837310
10/24/10 10:29 AM
10/24/10 10:29 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Screwed to the halo, behind where the rear view mirror would be.
Re: arc switch panel mounting [Re: S/ST 3040] #837311
10/24/10 10:38 AM
10/24/10 10:38 AM
S/ST 3040 Offline
S/ST 3040  Offline
I drilled a hole into the bracing at the corner of the roof and
ran the wire through a grommet, down the inside of the A-pillar.
Re: arc switch panel mounting [Re: fowl play] #837312
10/24/10 12:11 PM
10/24/10 12:11 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Heres a pic of mine. Still in the process of finishing up the wiring. Made the panel and attached with bar clamps.
Not arc but may give you an idea.
Re: arc switch panel mounting [Re: Todd] #837313
10/24/10 01:13 PM
10/24/10 01:13 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
2 zip ties and one hose clamp.
Re: arc switch panel mounting [Re: MegaDart] #837314
10/24/10 08:29 PM
10/24/10 08:29 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
mine was mounted on a roll bar but i moved it
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: arc switch panel mounting [Re: 67mprfan] #837315
10/31/10 01:10 PM
10/31/10 01:10 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Re: arc switch panel mounting [Re: racerx] #837316
10/31/10 01:20 PM
10/31/10 01:20 PM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
When 408dust did mine he welded a piece of tube at an 45* angle and mounted it well within arms reach.
Re: arc switch panel mounting [Re: fowl play] #837317
10/31/10 02:44 PM
10/31/10 02:44 PM
Super Scamp Offline
Super Scamp  Offline
I have the same switches nice setup I think.
Just One Man's Opinion Mopar Mafia Racing
