K Frame Clerance for Pan
#837191
10/23/10 11:53 PM
10/23/10 11:53 PM
Posts: 205 Illinois
gearhead01
Illinois
I once saw a sketch for the clearance notch in the K frame A Body)needed for a Milodon pan. I could not find it on their web site today. Does anyone have this sketch, ot pictures of their trimmed K frame?
Thannk you for your help.
John
1971 Satellite Sebring Plus - 14.46 @ 95.43 1977 Road Runner - N/B 11.02@ 119 Drag Radials
Re: K Frame Clerance for Pan
[Re: Randy..]
#837193
10/24/10 09:11 AM
10/24/10 09:11 AM
Posts: 4,243 Canada
Kam*Kuda
Canada
mine
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: Kam*Kuda]
#837195
10/24/10 09:16 AM
10/24/10 09:16 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Those are nice but you don't need to take out that much for the milodon small block pan. Mine has maybe a 3x3 notch in it. If you set the motor down in the engine bay you will see where it needs to be cut. Its small enough its no big deal to do it quickly while your putting the motor in.
68 Barracuda Formula S 340
[Re: Bad340fish]
#837196
10/24/10 09:19 AM
10/24/10 09:19 AM
Posts: 4,243 Canada
Kam*Kuda
Canada
Thats true. I only needed a small notch for my milidon pan in my e body. The heavily modified kframe is not really required in many cases
[Re: Kam*Kuda]
#837197
10/24/10 09:50 PM
10/24/10 09:50 PM
Posts: 205 Illinois
gearhead01
Illinois
Thanks for the pictures and descriptions. Milodon says only a 3/4" cut is required, and i saw an instruction sheet once a long time ago with the dimensions. I was looking for some one who might have that sketch.
Thanks again.
John
[Re: gearhead01]
#837198
10/25/10 12:45 AM
10/25/10 12:45 AM
Posts: 4,209 New York
polyspheric
New York
Milodon has let Buffy write the instructions. The size of the hole depends in large part on how well tied down your engine is. Worn stock motor mounts, or plates front and rear? Torque strut?
Do what you like on the X-member, but if you don't have life insurance it shouldn't look like that.
Boffin Emeritus
