Re: Vapor Lock
[Re: SomeCarGuy]
#837061
10/30/10 01:50 PM
10/30/10 01:50 PM
Posts: 1,639 Brandon, Ms
cornet684me
Brandon, Ms
here is a pic of the Fuel pump rod, nothing wrong with it, the car ran fine when i just hook up a house straight from the fuel pump, when i connect the hard line from the tank, the fuel filter goes empty after i crank the car and it is idling, i really do not have the money to do all the new stuff right now, i am trying to get this motor back running so i can sell it, and then i plan on replacing everything, i don't understand why when i hook up the hard line from the tank and put a hose from a gas can attached to the hard line bypassing my tank and sending unit, the fuel filter goes empty, i have checked the complete hard line and there are no leaks, it almost acts as though the fuel pump just stops working when i hook this line up?
Re: Vapor Lock
[Re: cornet684me]
#837063
10/30/10 01:58 PM
10/30/10 01:58 PM
RapidRobert
the pump/rod/line to carb/filter are good and the prob is rearward from the pump. That only leaves the hard line rearward (including the 2 neoprene connector hoses) OR the pickup assy. did you hook the jar to the neoprene connector hose at the tank? This'll tell you if it's the hard line/2 neoprene hoses OR the pickup assy.
Re: Vapor Lock
[Re: RapidRobert]
#837066
10/30/10 02:20 PM
10/30/10 02:20 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Whenever I get a straw w a minute crack in it w my McDonalds vanilla milkshake I get just enough to whet my taste buds then very little after that
Good analogy..
Re: Vapor Lock
[Re: RapidRobert]
#837067
10/30/10 02:22 PM
10/30/10 02:22 PM
cornet684me
Brandon, Ms
the hard line is the original, the car has been undercoated and the fuel line looks okay from the outside, so to save some money right now, can i buy a roll of that cheap alum. fuel line and run me a new line for now, so i can get the car back running to get the 440sold and then i am going back with my new 440 i just bought this week, so my question is, can i run a temp line for now to get the car running ? upon further investigation , the gas tank has had some repairs and i really need to replace, so my plan is , get the car back running, sell the current 440 and i will do all the upgrades, new tank, 3/8 stainless line, new 3/8 sending unit, i really just need the car running to get the motor gone
Re: Vapor Lock
[Re: cornet684me]
#837069
10/30/10 02:25 PM
10/30/10 02:25 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
What have i been saying, the hard line obvisously is the problem, or that short rubber hose that goes between the cross-frame by the trans crossmember, your running in circles, if your getting fuel from the pump too the carb, but once you try & run through the hardline is gets restrictive .
You have ruled out the Tank/pick-up/rod/pump, this sounds like a re-pete to me, i told you to yank out all that hardline & replace it, either with a role of 3/8 aluminum line from summit/jegs, The aluminum is very easy to bend & its cheap too, just use your old line as a template, OR a factory line, but there not cheap.
The mech. fuel pump will not have a problem sucking fuel from a long distance through curves/bends IF theres NO restrictions or air. . Its not "ROCKET SIENCE"
If theres "air" it would be dripping fuel on the ground.
Re: Vapor Lock
[Re: joedust451]
#837070
10/30/10 02:31 PM
10/30/10 02:31 PM
cornet684me
Brandon, Ms
thanks Joe, there are no fuel leaking on the ground , sorry for all the repeats, i am just frustrated , i will get a new hard line and i will get back with everyone, i thank everyone for there patience with me, i guess my problem is, i was trying to get by and i should have known to do it right the 1st time, i am on the way to parts house to get roll of fuel line and i will post the results when i crank up the car
Re: Vapor Lock
[Re: cornet684me]
#837073
10/30/10 04:29 PM
10/30/10 04:29 PM
joedust451
super gas
super gas
Branson, Mo.
I'm sure you will have problems finding "aluminum" line locally, i know i couldn't, the only other bet is "copper" at Home Depot or Lowe's, its a bit pricey & hard to bend for tight corners around the frame rail, the aluminum is the easiest & not as likely to kink. Once the hard lines been re-placed (along with the short rubber hose at the crossmember) & by ANY chance its still having issues, it'll make it alot easier to narrow it down. When i disconnect my hard line from the pump, it'll poor gas instintly & drain the tank, Oh but i'm running a fuel cell . Let us know how it works out!! http://www.jegs.com/i/Moroso/710/65330/10002/-1http://www.jegs.com/i/JEGS/555/15100/10002/-1
Re: Vapor Lock
[Re: joedust451]
#837076
11/07/10 10:52 PM
11/07/10 10:52 PM
cornet684me
Brandon, Ms
Joe, thanks for the link to Jegs, i went on line and ordered, the new line was at my door step by the 3rd day, i went with the Moroso, cheap however very stong. can you believe that i got put it in without a break, 1 line from fuel pump to the tank, i have to admit it took the better part of the whole day yesterday fighting with the shocks and exhaust. thanks
Re: Vapor Lock
[Re: cornet684me]
#837077
11/08/10 12:37 AM
11/08/10 12:37 AM
joedust451
super gas
super gas
Branson, Mo.
thanks
Glad you got it fixed, but i will tell you a buddy of mine ran mid 11s in his BB A body for 8 yrs. with the factory 5/16 line, BUT he ran a helper Elec. pump, I'm still convinced the factory line had issues somewhere because that gas NOW looks crystal clear .
