Re: Automatic motor in a 4 speed car
[Re: JeffRacerG]
#836951
10/23/10 10:23 PM
10/23/10 10:23 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
No external differences, you will have to actually look at the back of the crank. This is from memory so hopefully others will chime in- If I recall later model v-8 were all drilled only for torque converters, the manuals used a roller bearing that sat in the torque converter nose recess and adapted it down to work with manual input shafts. But it may require machining. In trying to look that up I stumbled across this post on another site that may also be helpful http://www.moparchat.com/forums/showthread.php?t=103034
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: JeffRacerG]
#836953
10/23/10 11:34 PM
10/23/10 11:34 PM
Posts: 1,169 MI
68shifter
MI
As the other poster stated no readily visible difference. You can either drill the crank a touch or cut the end off the input shaft. It won't hurt anything either way and there are a bunch of sticks out there with slightly shorter inputs. As evidenced by alot of Chevy guys cutting 833 inputs to fit their applications. Good luck ![](/ubbthreads/images/graemlins/thumbs.gif)
68' Barracuda (4 speed)
64' Savoy (4 speed)
65' Satellite (girl tranny)
