Page 5 of 5 1 2 3 4 5
Re: stock 400 build [Re: OrangeProwler] #835909
10/29/10 10:40 AM
10/29/10 10:40 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Dean I wanted to say thanks for the post. Looks like I got some tough choices to make.
Hey, no problem, it always feels good to help.
But remember, when on a budget, sometimes ya just got to throw it together with the most sound parts you have and enjoy it while you're saving up for the better combo.
Re: stock 400 build [Re: Dean_Kuzluzski] #835910
10/29/10 10:51 AM
10/29/10 10:51 AM
Middle of A Field
O
OrangeProwler Offline
O
Middle of A Field
Well Dean not to go OT but and not to be negative but, when you have someone who puts a lot of stipulations on you and keeps you on a tight budget and throws a lot of things around upon you it makes it a tough situation. Anyways, thanks again.
Re: stock 400 build [Re: OrangeProwler] #835911
10/29/10 07:25 PM
10/29/10 07:25 PM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
if you are on that tight of a budget,magnumminded,i have a stock 383 magnum cam/lifters (just pulled out of a less than 60,XXX mile 383 from a 69 roadrunner) i kept the lifters in order. you pay shipping,and they are yours. that way you won't have to shell out for new valve springs,and it will be better than your stock 2-bbl cam.
Re: stock 400 build [Re: Dean_Kuzluzski] #835912
10/29/10 10:54 PM
10/29/10 10:54 PM
pana illinois
bigblock4x4 Offline OP
pana illinois
Check the cc's of the heads and we can help you further.
If the 452's are equal to the 516's use the 452's. Reason being, hardened seats, 1.74 exh. valve, same compression, slightly better flow.
Ideally you want the compression of the 516's (w/the milled 452's) with the benefits of the 452's. And sounds like they are close.
If both sets of heads were equally worn and untouched, I'd update & freshen up the 516's. Just my opinion.
Cc'ing a set of heads can be as easy as putting some old spark plugs in, filling the comb. chamber with Play-Doh, cut the clay level with the deck surface, and then pull it all out and drop it in a beaker/measuring cup with a known amount of fluid. What ever it registers as a new amount is your "cc's".
use the 516's because of the quench??
Re: stock 400 build [Re: superbyrd] #835913
10/29/10 11:09 PM
10/29/10 11:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
if you are on that tight of a budget,i have a stock 383 magnum cam/lifters (just pulled out of a less than 60,XXX mile 383 from a 69 roadrunner) i kept the lifters in order. you pay shipping,and they are yours. that way you won't have to shell out for new valve springs,and it will be better than your stock 2-bbl cam.
Why wouldn't he need new springs? That cam used a different spring than the 400 2bbl.
Re: stock 400 build [Re: JohnRR] #835914
10/29/10 11:29 PM
10/29/10 11:29 PM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
by seat pressure,psi open,and closed,his stock springs would handle that 383/440 hp cam just fine. he is not going to be turning it over 4800-5000 rpm anyway. it will not make as much power as the aforementioned lunati,new springs,etc. but,he can get away with using it,and,heck,it's free.lol.
Re: stock 400 build [Re: bigblock4x4] #835915
10/30/10 02:48 PM
10/30/10 02:48 PM
Holly/MI
Holly/MI
What quench? In the original post he said the piston was ".100 in the hole". Never gonna happen.
Re: stock 400 build [Re: Dean_Kuzluzski] #835916
10/30/10 03:00 PM
10/30/10 03:00 PM
pana illinois
pana illinois
i didn't mean cause of the quench,i meant use them becaue of the closed chamber,sorry i goofed up.
Re: stock 400 build [Re: bigblock4x4] #835917
11/14/10 12:50 PM
11/14/10 12:50 PM
pana illinois
pana illinois
i had the ported 452's checked and they flowed 245cfm on the intake and 205cfm on the exhaust@.550"lift.not too shaby,think i'll be buying some better pistons to utilize the head flow?
Re: stock 400 build [Re: bigblock4x4] #835918
11/14/10 12:56 PM
11/14/10 12:56 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
i had the ported 452's checked and they flowed 245cfm on the intake and 205cfm on the [Email]exhaust@.550"lift.not[/Email] too shaby,think i'll be buying some better pistons to utilize the head flow?
that's better than stock , yes a piston that was closer to zero would be a better choice to bring up the compression . Did you have a chamber Cc'd to see what they were ? Did I miss that in the thread ?
Re: stock 400 build [Re: JohnRR] #835919
11/14/10 01:23 PM
11/14/10 01:23 PM
pana illinois
pana illinois
yes they were 80 cc's,they have been milled .060"
Re: stock 400 build [Re: bigblock4x4] #835920
11/14/10 04:34 PM
11/14/10 04:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Are you boring the block, if so to what size ?
Re: stock 400 build [Re: JohnRR] #835921
11/14/10 07:03 PM
11/14/10 07:03 PM
pana illinois
pana illinois
the block i have looks to b n great shape,was plannin on leavin it a stock bore,i traded a 318 for a nice standard steel 383 crank,i got lucky with the heads that i had and so i figured i might as well put a descent set of pistons in her to get the compression up.
Re: stock 400 build [Re: bigblock4x4] #835922
12/11/10 04:54 PM
12/11/10 04:54 PM
pana illinois
pana illinois
i don't want to go any farther than .030 over,i hope there's not much taper and i can leave it a stock bore with a nice hone job,i wanna keep it to as stock as i can,just give the ol girl the compression she deserved n the first place,descent set of heads and a little camshaft.it's gonna b goin in a 68 dart,so it'll b fairly light,wont need to much to have fun with all these furds and chebbies,
