Page 3 of 5 1 2 3 4 5
Re: stock 400 build [Re: DaytonaTurbo] #835869
10/25/10 03:38 PM
10/25/10 03:38 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
w/ patrick on the intake manifold choices. With the voodoo 60302 being a mild cam and ground on a 112LSA, you wouldn't see a huge difference between hp manifolds and cheapie headers.
I bet you would.....
Dulcich has shown a gain of at least that much on a number of "resto to rad" builds in mopar muscle on a dyno....granted it's westech's dyno that has been accused of being "happy", but look at the relative gain, since it's pretty much back to back pulls on the same dyno....
cleaned up, ported, extrude honed, etc HP manifolds will probably net you 1 or 2 HP over untouched.....heck, on the 300HP magnum crate motor, he saw 5hp difference between 318 and 340HP manifolds, and 10-20HP on top of that with various headers, and similar torque improvements throughout the RPM range.
2017 Grand Cherokee Overland
Re: stock 400 build [Re: patrick] #835870
10/25/10 03:44 PM
10/25/10 03:44 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yes, however cams with a wider LSA tend to be not quite as sensitive to headers vs hp manifolds in as mild of an application like this. I think he could see a 10-20hp difference at best with headers vs hp manifolds, however whether or not he considers that significant enough to justify going to headers, that's up to him.
Re: stock 400 build [Re: DaytonaTurbo] #835871
10/25/10 03:56 PM
10/25/10 03:56 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Ok...now what about shorty headers vs. full length? I'm wondering if the tradeoff in performance would be worth the ease of use with shorties?
Earning every penny of that moderator paycheck.
DBAP
Re: stock 400 build [Re: not_a_charger] #835872
10/25/10 04:00 PM
10/25/10 04:00 PM
Manitoba, Canada
Manitoba, Canada
No experience with shorties myself, but all the ones I've seen make them look like they'd be a nightmare to make fit around a power steering box/starter area.
Re: stock 400 build [Re: DaytonaTurbo] #835873
10/25/10 04:03 PM
10/25/10 04:03 PM
The Hedman shorties require a mini starter, so maybe they're not as easy to use as I'd hope.
DBAP
Re: stock 400 build [Re: not_a_charger] #835874
10/25/10 04:06 PM
10/25/10 04:06 PM
Manitoba, Canada
Manitoba, Canada
I would be more concerned if the header collector wants to occupy the same space as the power steering box!
Re: stock 400 build [Re: DaytonaTurbo] #835875
10/25/10 04:09 PM
10/25/10 04:09 PM
Yeah, same here.
I'm thinking that for a nice street cruiser, that any of the mild combos listed here would be just fine with HP manifolds.
DBAP
Re: stock 400 build [Re: not_a_charger] #835876
10/25/10 04:13 PM
10/25/10 04:13 PM
Manitoba, Canada
Manitoba, Canada
I dunno, the cheapie summit headers fit my car well and don't hang down low at all. If I had to do it all over, I would buy the summit cheapies again.
Re: stock 400 build [Re: not_a_charger] #835877
10/25/10 04:16 PM
10/25/10 04:16 PM
Central NC
gch Offline
gch  Offline
Central NC
No matter what you use I would run the mini starter.Gives you more clearance everywhere and spins so much quicker.
Old HP mopar mag article dyno tested hp man vs shorties vs long tube headers on a stock 440 with no other changes.
The difference from man to shorties was about the same as shorties to full length.Sorry I don't remember the actual numbers.Where the full length shine is low/mid range torque.The shorties were a noticeable gain over manifolds in both.
Re: stock 400 build [Re: gch] #835878
10/25/10 04:21 PM
10/25/10 04:21 PM
Manitoba, Canada
Manitoba, Canada
Definitely do a mini-starter regardless. So much easier to lift and hold in place while you bolt everything together. I scored one out of a late 80's dodge ram van in the junkyard.
Re: stock 400 build [Re: DaytonaTurbo] #835879
10/25/10 04:37 PM
10/25/10 04:37 PM
Middle of A Field
O
OrangeProwler Offline
O
Middle of A Field
Not to mention the minis shave a few pounds.
Re: stock 400 build [Re: DaytonaTurbo] #835880
10/25/10 04:43 PM
10/25/10 04:43 PM
pana illinois
bigblock4x4 Offline OP
pana illinois
i alreay got the headers,and an intake,still gotta get a carberator,ignition,and timing chain,and also rings got a tranny and convertor,also need 8 3/4,gonna leave it column shifted i'm gettin closer by the minute(or as my budge allows)thanks everyone for yor input it is helpin more than you know.
Re: stock 400 build [Re: DaytonaTurbo] #835881
10/25/10 04:44 PM
10/25/10 04:44 PM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
but,all the magazine gurus,hype,and crap,is all with all the carb they can run,with maximum jetting,and peak rpm horsepower,blah,blah,blah. not at driving around town and street crusing,where,you will not notice a lick of difference between cleaned up HP manifolds and cheapie headers. and then factor in the future leaks,tight fit,etc. not worth it. really. and the difference in 2 1/4 over 2 1/2. on your car,with the weight and all things considered,2 1/4 will more than suffice. i don't know how many people you see on this board,and alot of other places,that are barely making 400hp and actually believe they "need" 2 1/2 or 3" mandrel bent exhaust on their cars.lolol really. well,i guess they might think that if they listen to all that "magazine,perfect world,on paper,westech dyno proven" bullcrap. i read that stuff for what it is.......good reading. then i go with what works in the real world,on the street,etc.
Re: stock 400 build [Re: superbyrd] #835882
10/25/10 06:17 PM
10/25/10 06:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
i have nothing of value to ad
Your sig pretty much sums this post up .
Re: stock 400 build [Re: JohnRR] #835883
10/25/10 07:42 PM
10/25/10 07:42 PM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
lots of folks come on here,asking for help,and answers,wanting input on how to make power,most on a budget,or not alot to work with,and the same ole' answers file in.
you guys who swear by the "experts",and magazine "gurus",ever wonder how in the world guys 30-40 years ago ever got a car to move down the track,or make a single horsepower,without your "quench" this,and stroked that,and so and so says this and that won't work???? must have been some kind of miricale. must have never happened.amazing..............
Re: stock 400 build [Re: superbyrd] #835884
10/25/10 07:46 PM
10/25/10 07:46 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I've run a bunch of cheap headers, never had a leak never had to beat and bang them and never banged them up on the ground. If you think Mani's even hi-po units flow as well as a headers you're nutz. Maybe if you run the same choked up 2" exhaust, but with 2.5" and the 1 3/4" tube headers you will pick up HP and MPG's (if you care about that kind of thing).
Coming soon!!!!
Re: stock 400 build [Re: DaytonaTurbo] #835885
10/25/10 07:49 PM
10/25/10 07:49 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
that's what I got and a mini starter. Fit fine w/ PS too.
Re: stock 400 build [Re: Mr.Yuck] #835886
10/25/10 07:55 PM
10/25/10 07:55 PM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
not saying the manifolds flow as well as the headers,or even make as much power. but,alot of folks DO have those problems. snag them on speed bumps,have leaks over time,etc. on the same side of that coin,most run stock starters(and constantly cook them)run poor gaskets (that soon leak)and get tired of the tight fit. my standpoint on headers,is,majority of folks car will see little,or no track time. much less rarely ever run for over a few seconds above 4000 rpm. with those factors, huge pipes,and headers are going to produce very little "seat off the pants" feel. cruising around the dairy queen,you won't be able to tell the difference.
Re: stock 400 build [Re: superbyrd] #835887
10/26/10 01:20 AM
10/26/10 01:20 AM
Manitoba, Canada
Manitoba, Canada
Crusing around the dairy queen you won't feel the difference between a 318 and a 440 either. It's all about what you want it to do when you hit the GO pedal. You're right, those not taking their cars to the track need not squeeze every last hp out of their car if they don't want to. I don't think anyone in this thread was suggesting quench or strokers. He said he's on a budget and we all understand. FWIW, cheapie headers usually cost less than what HP manifolds go for.
Re: stock 400 build [Re: DaytonaTurbo] #835888
10/26/10 09:14 AM
10/26/10 09:14 AM
pana illinois
pana illinois
my buddies buildin a 74 dart sport with a 440,his is definatly gonna run better,but i'm always messin with him,we ARE definatly gonna run em at the strip a little,i just want to get the most outa what i got,no since in not racing,that's what it's all about oh and it's a 1/8th mile track so i should be able to maybe get away with a little more gear if recommended i said 3.91's but maybe 4.10's???
