Page 1 of 5 1 2 3 4 5
stock 400 build #835829
10/21/10 10:22 PM
10/21/10 10:22 PM
pana illinois
bigblock4x4 Offline OP
pana illinois
ok guys,i am on a tight budget,i have a bone stock 400 i don't have the money to swap pistons,the pistons are .100 in the hole,i got a set of 452's that are 80cc(and some mild port work) and i also have a set of bone stock 516's,which would you guys use?i have picked out 2 cams one is a voodoo 262/268 220/226@.050 .475/.494 on a 108 or a comp xe268h 224/230@.050 .477/.480 on a 108 centerline.i have figured compression to be 8.5 to 1 with a .020 steel head gasket.got an old strip dominator intake and a descent set of headers and a 750 holley,does it sound like it will run ok??goin n a 68 dart it's light so it should be fairly quick????
Re: stock 400 build [Re: bigblock4x4] #835830
10/21/10 11:49 PM
10/21/10 11:49 PM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
go with the 516's and the XE268. it will run great. my 2 cents.
Re: stock 400 build [Re: superbyrd] #835831
10/22/10 11:35 PM
10/22/10 11:35 PM
South Dakota
Mirada440 Offline
Mirada440  Offline
South Dakota
The 516s are boat anchors, If read in the mopar bible you dont want to put the 516s on a 400... Ive looked into the 400s alot in the past because my brother and i were both doing builds like yours, Use the 452s and a 268 cam Aluminum intake and holley 750 DP, quick advance springs, headers or good manifolds and she will run hard....
Re: stock 400 build [Re: Mirada440] #835832
10/22/10 11:53 PM
10/22/10 11:53 PM
pana illinois
pana illinois
we here have been gettin TERRIBLE RESULTS with any comp but if you guys think the comp is better let me know why???i have never ran one,but there are 3 peope near by that have had there cams go flat in about 10 minutes,and they followed there break-in procedures to the letter,i was there,if it's good i'll use it,but i cant afford to tear down an engine every time they go flat.what did your car run like with that build?i got a 68 dart that should weigh somewhere in the neighborhood of 3000-3200 lbs
Re: stock 400 build [Re: bigblock4x4] #835833
10/23/10 08:14 AM
10/23/10 08:14 AM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
well,i don't read the "bible",i just go with what works. i have built 3 different 400's,using the closed chamber 516's for cheap and easy compression bump. you already have them. your 400 has pistons anywhere from .090 to .115 in the hole. the 452's will keep it at about 7.6 to 1. the 516's will bring it to 9 to 1.
current one i have, 66 coronet 2-door sedan(3700 lbs.)77 400,stock bottom end,no decking,uncut,unported 516's,comp XE268,performer RPM,750 holley VS carb,cheapie summit headers,2400 converter,8 3/4 with 3.55's. car runs on 255/60/15 BFG drag radials, have atleast 50 time slips between 12.94-13.10 in the quarter.do the math. i'm just saying,the 516's work, pretty sure thats not in the "mopar bible",but,the time slips don't lie.......
Re: stock 400 build [Re: Mirada440] #835834
10/23/10 09:06 AM
10/23/10 09:06 AM
IL
71383beep Offline
71383beep  Offline
IL
closed chamber heads...boat anchors...right!
I guess by your logic my boat anchor equip'd 383 would have been better off with the 906's it originally had on there which resulted in a fantastic CR ratio of 7.8:1. With those boat anchors I managed to pick up the CR to 9.2:1 with some minor decking...try doing that with an open chamber head...
To me I would not even waste time on an open chamber head...they are the true "boat anchors" in my book.
It is true the valve sizing and port design are not the best. that is why the 915 is more desirable, but the closed chambers make up for a lot of that...especially on 383/400's where piston choice is so poor.
Like anything they need some work to make do, bigger valves, porting, etc. but if your simply gonna do a straight out comparison by bolting on a set of 516's vs ANY open chamber head the closed chamber head will result in more compression = more power.
Wasn't 383HP running a set of 516's on him or his sons dart on a 400 that was running in the low 12's or something?
'73 GK6 Challenger Rallye - 340 4-Speed
Re: stock 400 build [Re: bigblock4x4] #835835
10/23/10 09:18 AM
10/23/10 09:18 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
There seems to be a bad run for Comp users as of late, I would go with your gut on it .
Re: stock 400 build [Re: 71383beep] #835836
10/23/10 12:29 PM
10/23/10 12:29 PM
pana illinois
pana illinois
the 452's that i have are 80 cc's and have had some bowl work,if the 516's r better i'll use em,should i put the better exhaust valve n em first and have everthing checked?they are bone stock as they sit,and the milled 452's are ready to bolt on,thanks everyone for the responses
Re: stock 400 build [Re: bigblock4x4] #835837
10/23/10 01:01 PM
10/23/10 01:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You won't see much of a compression increase going to the 516's because of how much the 452's have been cut , I'd use the 452's if they are ready to run .
Re: stock 400 build [Re: JohnRR] #835838
10/23/10 02:25 PM
10/23/10 02:25 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
lots of good info in the archives for those willing to look. http://www.moparts.org/Tech/Archive/bb/42.html http://www.moparts.org/Tech/Archive/bb/62.html
Re: stock 400 build [Re: forphorty] #835839
10/23/10 02:40 PM
10/23/10 02:40 PM
Central NC
gch Offline
gch  Offline
Central NC
I say run the 452's and don't over cam it.Compression helps power but I would rather have flow.Many low compression motors haul a** with good heads and well matched combinations.
Of the two cams listed I would run the voodoo.Pick up a used rpm intake(you will want a dual plane)and run the rest of your combo.
You could always mill the 452's a little more if it makes you feel better.
You did'nt mention what gears you will be running.With a low gear you might get away with a little more cam.
Re: stock 400 build [Re: gch] #835840
10/23/10 04:41 PM
10/23/10 04:41 PM
might checkout Dulcichs' porting articles in the Mopar Muscle archives. (3 part articles/excellent) & iirc there was some area on 516's that should not be touched (short side radius on the ex side?) that is std procedure to be reworked on all other iron OE heads but that they definitely can be made to flow. They do have a bad rep & might be if you touch that area they will flow worse which is maybe why.
Re: stock 400 build [Re: gch] #835841
10/23/10 05:00 PM
10/23/10 05:00 PM
pana illinois
pana illinois
gonna run 3.91's,and i got a 3000 convertor already,not sure how much they've been milled already,don't want to get into too many valvetrain issues,as i am on a tight budget,(wife nagging),thanks everybody this is very helpfull.
Re: stock 400 build [Re: bigblock4x4] #835842
10/23/10 05:04 PM
10/23/10 05:04 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd have the 452's cut .020 and use the XE 268. Since the 516's are stock the 1/2 point of compression won't help as much as the ported heads.
Coming soon!!!!
Re: stock 400 build [Re: Mr.Yuck] #835843
10/23/10 09:06 PM
10/23/10 09:06 PM
South Dakota
Mirada440 Offline
Mirada440  Offline
South Dakota
The 516s are small valve boat anchors, They are not a decent head unless they have alot of work done to them....The 452s are a good head and if you use the comp XE cams they are designed to run with low compression motors... If you do your research has in mopar performance/direct connection race books it tells you right in to the book to NOT use closed chamber heads on a stock 400 as it hurts performance I need to look it back up in the book but it has something to do with the quench, etc... compression is important but trying to gain a 1/2 a point or so of compression by using poor heads is like farting in a windstorm, Your better off using your 452s with a smaller XE comp cams a factory highstall convertor with the 391s and it will run good.... If anyting do what was said above and save a few bucks and have the 452 heads shaved to boost the compression the biggest thing i can say is dont over cam it, stay at a 268 or even a 262 comp i wouldnt go much bigger, Those cams with a good dual plane intake will make lots of torque...
Re: stock 400 build [Re: Mirada440] #835844
10/23/10 09:09 PM
10/23/10 09:09 PM
South Dakota
Mirada440 Offline
Mirada440  Offline
South Dakota
I seemed to have over looked where you said the 452s are cut already, I think there is no question on what head to use if you have 452s ready to go....
Re: stock 400 build [Re: 71383beep] #835845
10/23/10 09:42 PM
10/23/10 09:42 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I ran the lunati voodoo 60303 cam in a 70's low compression 440 and it ran quite well after I curved the distributor to suit it. The voodoo 60302 would make for a good running cam in your combo and being a 400 instead of a 440 you'd likely want to take it a notch down from what I ran .
Same here. His have supposedly already been cut so I would make an exception but in general .
the 452's that i have are 80 cc's and ...
Are you sure on the 80cc? To get 452's do to 80cc, I think you need to whack something like .100" off them. That much milling introduces some other issues as well...
If you do your research has in mopar performance/direct connection race books...
FWIW I have one of the direct connection race books and there's so much crap info in there I threw it on the shelf and haven't looked at in in years.
Re: stock 400 build [Re: DaytonaTurbo] #835846
10/23/10 11:37 PM
10/23/10 11:37 PM
pana illinois
pana illinois
they are for sure 80cc my friend checked em for me to make sure,might have to get some different length pushrods???they've been ported on some already that's the main reason i would like to use them,but i really am not that picky,it's not gonna make 500 hp either way,there's different ways to skin a cat,all you guys have been a big help and i apprciate it a lot
Re: stock 400 build [Re: bigblock4x4] #835847
10/24/10 01:27 AM
10/24/10 01:27 AM
Manitoba, Canada
Manitoba, Canada
You may have to get shorter pushrods. Would be nice if you knew how much they were milled. Like I said, I *think* you have to take off about .100 to get them down to 80cc considering they were originally more like 90cc. I do remember thinking about doing that at one point, taking .120" off a set of 452's for a smogger motor. But I would have needed shorter pushrods, cut down the intake flangs on the heads, then the valley pan wouldn't have wanted to fit right anymore either. Bolt holes on the intake get thrown off a bit with that much milling as well. Once you get everything matched up properly, it should run decent for what it is.
Re: stock 400 build [Re: DaytonaTurbo] #835848
10/24/10 01:51 AM
10/24/10 01:51 AM
Valencia, España
NachoRT74 Online content
NachoRT74  Online Content
Valencia, España
10 cc less is more like 0.050 cut not 0.100
