Re: Hemi & ATI balancer
[Re: AndyF]
#835655
10/22/10 12:28 PM
10/22/10 12:28 PM
Posts: 17,904 S.E. Michigan
ZIPPY
S.E. Michigan
I use a 3 ring on my wedge. The shorter crank pulley I use is a Moroso underdrive, but it's actually a tad bit too short and I had to put around a 1/8" shim behind it.
Rich H.
Esse Quam Videri
[Re: hemicop]
#835657
10/23/10 02:33 PM
10/23/10 02:33 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
It's a single groove pulley, as is the water pump. The outer "lip" of the water pump pulley lines up with the "lip" of the crank pulley that;s nearest the engine (aka engine side "lip".). My concern spacing just the pulley out is that it may exert too much leverage on the water pump shaft/bushing leading to premature wear. That's why I was thinking I'd have to resort to spacing out the pump housing. BUt the responses Do help so far. Thanks!
Are they hemi pulleys or wedge pulleys or a combination of the 2 ?
[Re: hemicop]
#835658
10/23/10 02:40 PM
10/23/10 02:40 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Then change the crank pulley and be done with it. All you need is the DMI pulley, a 2" crank bolt (you should already have this if you're using a 3 ring balancer), (6) 5/16" X 1-3/4 hex head bolts, and a shorter belt. I'm running the single groove set up, too. I've done all the leg work on this parts-wise, but I can't promise the parts will work unless you verify the difference is 5/8". If it is you'll be able to use the new pulley right out of the box.
[Re: JohnRR]
#835659
10/23/10 02:44 PM
10/23/10 02:44 PM
64Post
Baltimore/Denver
What is the difference, John? Bolt pattern?
[Re: 64Post]
#835660
10/23/10 05:16 PM
10/23/10 05:16 PM
JohnRR
U.S.S.A.
No depths , mid 68 - 71 hemis used a different top and bottom pulley than 66-mid 68 , the 66-mid 68 use a wedge water pump pulley and an even shallower crank pulley.
[Re: JohnRR]
#835661
10/23/10 08:28 PM
10/23/10 08:28 PM
Posts: 1,141 Phoenix,Az.
hemicop
Phoenix,Az.
The crank pulley is a 440 unit from "440 source". The water pump pulley, I was told is a 440 unit also so I'm thinking it should all line up.
[Re: hemicop]
#835662
10/23/10 08:40 PM
10/23/10 08:40 PM
JohnRR
U.S.S.A.
The balancer plays a huge role in this, if the hub is thicker than a stock wedge balancer there is no way you are going to get it to line up without a bunch of work. I'd be looking at a different lower pulley if you are set on your waterpump pulley. One thing you need to think about also is clearance to your radiator if you space out the waterpump.
[Re: copchaser]
#835664
10/23/10 10:24 PM
10/23/10 10:24 PM
hemicop
Phoenix,Az.
I run ATI balancers on all of my big motors. Try a stock street hemi crank pulley, or a 69/older small block crank pulley. If you run the small block pulley you'll need a narrow spacer. Mancini sells the spacers, or rob one off of a old bigblock industrial engine.
But I won't need the spacer if I use the Hemi Pulley? What's the part no.?
[Re: JohnRR]
#835666
10/24/10 02:33 AM
10/24/10 02:33 AM
64Post
Baltimore/Denver
Fan-to-radiator clearance is why I did all the legwork on my fitment. Early B's are notorious for lack of clearance, then add a 3 core and the Jag fan clutch and it gets even tighter.
