How to remove K-member bolts? #83560
07/03/08 04:34 PM
07/03/08 04:34 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Are these removable with a breaker bar or do I need an impact wrench? I actually have a socket large enough to fit the bolts holding the K-member onto my car (67' Barracuda). But when I tried to take one off, I couldn't budge it. Thanks for any help.
Re: How to remove K-member bolts? [Re: Fab64] #83561
07/03/08 04:38 PM
07/03/08 04:38 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Mine came loose with a breaker bar, but they were pretty stiff. Nothing wrong with using an impact gun if you have to.
Re: How to remove K-member bolts? [Re: Fab64] #83562
07/03/08 04:40 PM
07/03/08 04:40 PM
Haysville, Kansas
rdrmod6 Offline
rdrmod6  Offline
Haysville, Kansas
they should come off with a breaker bar, just make sure you are turning it the right direction. I broke one off of a 69 dart when I was 16, and removing the broken piece was a pain.
Re: How to remove K-member bolts? [Re: Fab64] #83563
07/03/08 04:58 PM
07/03/08 04:58 PM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
make sure to use some penetrating oil.Seems like I remeber seeing holes in the area of the bolts or maybe drill some really small ones above the bolts to spray lube.
Re: How to remove K-member bolts? [Re: snuggles] #83564
07/03/08 05:07 PM
07/03/08 05:07 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Thanks for the info - I guess I just need to eat more Wheaties?
Re: How to remove K-member bolts? [Re: Fab64] #83565
07/03/08 05:12 PM
07/03/08 05:12 PM
a cornfield near you
BlakDak Offline
BlakDak  Offline
or slide a jack handle over your breaker bar...:D
Re: How to remove K-member bolts? [Re: Fab64] #83566
07/03/08 05:12 PM
07/03/08 05:12 PM
BDW Offline
BDW  Offline
Go to home depot, get a 2-3' section of pipe to go over your breaker bar for leverage. Amazing how easy they turn.
Re: How to remove K-member bolts? [Re: snuggles] #83567
07/03/08 05:32 PM
07/03/08 05:32 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Very important, soak em good with oil FIRST. Inside and out, there are holes nearby where you can squirt oil in there.
Re: How to remove K-member bolts? [Re: Challenger 1] #83568
07/03/08 06:21 PM
07/03/08 06:21 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
What they said. Kroil is great for that application.
http://www.kanolabs.com/google/
Re: How to remove K-member bolts? [Re: Lefty] #83569
07/03/08 06:30 PM
07/03/08 06:30 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I just put mine back in last weekend, the torque spec is 150ft/pounds. So add some time and rust = big breaker bar or pipe...
68 Hemi Road Runner
Re: How to remove K-member bolts? [Re: 68jim] #83570
07/03/08 08:39 PM
07/03/08 08:39 PM
I drilled (4) small holes & oiled them daily for (3)days as I read somewhere that a guy did that(sometimes I get anal about these things!) they came out smooth as butter. I shudder to think of what would have been in store for me if one would have broken off. So you gotta ask yourself do you feel lucky PS they have only been(probably) untouched for 30 years or so.
Re: How to remove K-member bolts? [Re: BDW] #83571
07/03/08 08:51 PM
07/03/08 08:51 PM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
My heavy duty 1/2' impact wouldnt budge some but they are no match for a breaker bar and 3 foot of "cheater" pipe.
Re: How to remove K-member bolts? [Re: mopowergtx] #83572
07/03/08 09:43 PM
07/03/08 09:43 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
The torque to undo the bolt should be the least of your worries. The nut spot welded inside the frame should be of concern.
Re: How to remove K-member bolts? [Re: Magnum] #83573
07/03/08 10:13 PM
07/03/08 10:13 PM
Cincinnati, Ohio
Cincinnati, Ohio
That's what I was thinking.
Re: How to remove K-member bolts? [Re: Magnum] #83574
07/04/08 02:11 PM
07/04/08 02:11 PM
London, England
Gavin Offline
Gavin  Offline
London, England
What he said
Do the soaking thing - I also soaked mine for several days or more, they came out fine. Better safe than sorry
Re: How to remove K-member bolts? [Re: Fab64] #83575
07/04/08 02:30 PM
07/04/08 02:30 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
if you take out the rear bolt on your front bumber bracket. you will now have a open hole in the frame right over k-frame front bolts. oil can them with trans fluid and it will run down to other set. heat one at a time with hand held bottle torch, never impact, ive used my 3/4 inch rachet on over 50 rot boxes ive chopped up, to get the k-frame out never spun an insert yet.
MOPAR OR NO CAR
Re: How to remove K-member bolts? [Re: hemigod426] #83576
07/04/08 04:58 PM
07/04/08 04:58 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Hey thanks for all the replies, guys. I hadn't considered the nut spot-welded inside the frame. I'll try soaking everything as much as I can, then see what happens. Thanks again.
Re: How to remove K-member bolts? [Re: Fab64] #83577
07/04/08 06:02 PM
07/04/08 06:02 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Seeing that you are in SoCal, I doubt you will have an issue breaking the weld nut. I have spun a few in my day, but with NY rotters
