70 challenger amp guage is pegged
#835559
10/21/10 04:23 PM
10/21/10 04:23 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Just broke out the convertible after sitting since april. The Amp guage is pegged. Voltage regulator? How do I test it?
Re: 70 challenger amp guage is pegged
[Re: stumpy]
#835561
10/21/10 05:05 PM
10/21/10 05:05 PM
mikeysmopars
fresno ca
Has a fresh battery, & fires right up. even with the headlights on high beam it pegs the guage.
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: mikeysmopars]
#835562
10/21/10 05:15 PM
10/21/10 05:15 PM
Posts: 704 USA
rftroy
USA
I'm assuming you mean it is pegged on the charge side. Is that right?
Even if the regulator is bad and the voltage is too high, a gauge pegged on charge means that a lot of current is flowing.
Unless the ammeter is faulty, you have a short.
Best turn it off and look for the short, downstream of the ammeter, before something burns up.
However, as stated earlier, also make sure that the current isn't going to the battery.
Bob
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: rftroy]
#835563
10/21/10 05:19 PM
10/21/10 05:19 PM
mikeysmopars
fresno ca
I was hoping you wouldn't say that. What could be shorted?
[Re: mikeysmopars]
#835564
10/21/10 05:43 PM
10/21/10 05:43 PM
Posts: 704 USA
rftroy
USA
Boy, a lot. Forgot to ask though, what is you alternator output rating?
I'm going to back off a bit here and say it could still be a bad voltage regulator trying to overcharge the battery; or you could have a short which is draining the battery with the key off. When you say pegged, is the needle up to the C, or does it look like it is physically up against a mechanical stop?
I'd have to look at the wiring diagram, but if the regulator is causing overcharge, you will end up burning up the fusible link. An easy test is to start the car and put a voltmeter across the battery. It's better to test the voltage across the voltage regulator directly, but if it's an overcharging problem, the battery should do OK. If the voltage reads much more than 14.5 V, or is erratic and high, it is overcharging and the regulator isn't working right. You want close to 14. Over 15 is bad.
If the charging system is good (and you should probably go to a shop and have it tested) then you may have a short elsewhere in the system. If it is downstream of a fused circuit, you will blow a fuse; if it is between the ammeter and the fuse block, you might get a fire.
Charging system first. Make sure that it really is in as good condition as you think it is. I agree with Stumpy. A real overcharge is easy to measure, but it is best to have the system checked by a good mechanic.
Bob
[Re: rftroy]
#835565
10/21/10 05:46 PM
10/21/10 05:46 PM
mikeysmopars
fresno ca
thanks Bob, I'll have the shop check the voltage and give an update. Thanks Mike
[Re: IMGTX]
#835569
10/21/10 09:10 PM
10/21/10 09:10 PM
RapidRobert
Assuming VR has a good ground, at a fast idle disconnect the voltage reg and if the ammeter goes slightly to the discharge side, R&R the VR. As said DO NOT continue to run it as is.
[Re: RapidRobert]
#835570
10/21/10 11:38 PM
10/21/10 11:38 PM
mikeysmopars
fresno ca
Thanks everyone. I braved driving it home from work about ten miles and started checking things. I first put a charge on it and changed the voltage regulator. checked all the bulkhead connectors and looked at all the connections. refired it and is better but is still pushing the guage but not pegging it. I drove it tonight for about 45 minutes and looks to have come down a little more, i'll take a good look at fusebox tomorrow. Appreciate the feedback!!
