Re: First paint job and ???
[Re: Mopar_Ray]
#83500
07/03/08 05:18 PM
07/03/08 05:18 PM
Posts: 673 Long Valley NJ
65Belv DDB
mopar addict
mopar addict
Long Valley NJ
I'm in the middle of the my first paint job. I am going to finish with Chromabase. Started by taking car down to bare metal then used nason etch primer followed by a couple coats of nason 2k high build primer. Found some spots that need a little filler work, then will shoot 2 or 3 more coats of high build. I plan on blocking everything down with 400 (dry).
Now the???
1. Should I sand any further...thinking of 600 (wet) or?
2. Should I use some type of sealer before chromabase, I'm using nason 421-17 (buff) high build and chromabase will be "Go Mango" orange.
3. How much paint and clear do I need to order? The car is a 1970 Dodge Challenger.
No paint expert but here is my experience..
1. I sanded to 400, I don't think you need to go as far as 600.
2. Before applying paint I laid down 2 thinned coats of epoxy primer as my sealer. Not sure but you may be able to order white epoxy and have it tinted? Your paint supplier can show you a generic chip and how much of a difference primer color can affect paint color. I don't think I would want to paint mango orange over gray or black..
3.Better to have to much than not enough. I know from experience. If you are painting the entire car, including engine bay, trunk, etc. 2 gallons of paint and 2 gallons of clear should do you good with some leftover for any small fixes you may need later.. Even if you do not use it all, once you start buying quarts after the fact, you may have color match problems and the costs savings is insignificant. laid the paint/clear myself (2nd car I have done), and the color I chose (which is a deeeep red/black) needed to have 4 coats of color applied to get really solid coverage, then laid down 4 coats of clear. I still neeed to wet sand and buff, but you can spray todays clears and have very minimal 'orange peel'.
Good luck!
'65 Plymouth Belvedere '05 Dodge Ram Daytona
[Re: Mopar_Ray]
#83503
07/03/08 06:23 PM
07/03/08 06:23 PM
65Belv DDB
mopar addict
mopar addict
Long Valley NJ
You will still need to use a primer sealer or epoxy over the high build primer and you won't use more paint whether it is 400 or 600 as your final sand. One gallon should do it under the circumstances, but I would have an extra quart on hand just in case. I'd also rethink the use of Chromabase. It IS expensive, and for what it sounds like you are doing (not a full on resto), why not just stick with the Nason?
Post deleted by Defbob
[Re: Mopar_Ray]
#83504
07/03/08 06:29 PM
07/03/08 06:29 PM
#83505
07/03/08 06:42 PM
07/03/08 06:42 PM
Posts: 2,499 God's Country Maryland
GODSCOUNTRY340
Final wet sand with 400 grit, seal with Dupont Velvaseal, let it haze over, then lay down the basecoat. If you're going to buff the clear later, which is recommended, cover with at least three coats of clear. I like to let the clear dry for two days, block wet sand with 2000 grit and buff. Use a hand held spray bottle with water and dawn dishwashing liquid for wet sanding, keeps the paper from sticking.
[Re: Greg]
#83509
07/03/08 07:43 PM
07/03/08 07:43 PM
Posts: 512 Illinois
Mopar_Ray
Illinois
Please paint that god awful car from that dreadful yellow to a beautiful orange! I know my new car is currently Yellow. I am sure it has orange primer though. Here is Ray's car looking awesome in his new color.
Yeah.. its getting there . But you know...2, 3 weeks out?
